  #1
Old 03-26-2012
kenneth549 is on a distinguished road
Im gonna do about 14' OF CHAIN BEFORE MY RODE ON MY ANCHOR LINE FOR A 25FOOTER
What size Do you recommend? Thx.. Also, what 'kind of chain?' thx again
  #2
Old 03-26-2012
klem is on a distinguished road
Re: Im gonna do about 14' OF CHAIN BEFORE MY RODE ON MY ANCHOR LINE FOR A 25FOOTER
Chain serves a few purposes. First, it provides a connection from the anchor to the bow of the boat so it must be strong enough. Second, it provides chafe protection for your anchor rode so how much chain you need is determined by whether you anchor in a place with chafe. Third, chain will help your anchor set because it will keep the shank on the sea floor.
What are the absolute worst conditions that you expect to anchor in? Also, what type of boat do you have? The chain needs to be strong enough for this situation. For reference, the ABYC recommends a working load of 1500 lbs for your boat on a permanent mooring. 1/4" G40 has a working load of 2600 lbs so that would be more than adequate. Just make sure to replace your chain once it starts to significantly deteriorate.
Since you have already settled on a length, I am going to assume that you have taken into account whether you will be dealing with coral or anything else that will require the use of more chain.
What model of anchor do you have? For most anchors, setting can be helped by more, heavier chain. The exception to this that I know of is fortress anchors in very soft bottoms but they have good guidelines on their website. If you plan to anchor on short scope, heavier chain will be necessary but if you plan to use adequate scope, then the 1/4" chain mentioned above will be fine. For short scope anchoring, I would consider 5/16" G30.
  #3
Old 03-26-2012
KIVALO's Avatar
KIVALO is on a distinguished road
I have a 26ft boat and I use 12' of 1/4" galvanized chain & 150' of line with a Danforth anchor. I have had zero issues thus far. Also my mooring has 20' of 1/4" galvanized and 20' of 1/2" line attached to 3 augers sunk into the lake floor. The chain is well over 10 years and no issues at all. I did swap out the line last year though.
Brad
s/v KIVALO
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
  #4
Old 03-26-2012
CapnBilll is on a distinguished road
I use 16' of 3/8 BBB with a 40lb anchor on a 36' boat, but that is a little overkill. Upside I don't drag even in mud.
Tell us more, what size,type of boat?
Where do you plan to anchor?
What type of anchor? (don't start another anchor thread ), just traditional, spade, plow, etc...
What size of anchor?
On a 25 footer especially for day anchoring, you don't need an excessive ground tackle. But I would, (and do), keep a second storm anchor in a locker for unexpected storms.
The Sun has Risen on a New Day filled with the Promise of Adventure.
  #5
Old 03-26-2012
blt2ski's Avatar
If this is for the permant anchoring you are talking about, an ALL chain rode with the BIGGEST anchor you can set would be best. If a normal overnight anchor, then a 10-15lb danforth, 8-12lb bruce, claw, spade or equal with the amount of chain you propose would be fine for around the salish sea.
marty
She drives me boat,
I drives me dinghy!
You may post attachments
You may edit your posts
New Windlass twisting line / chain - change 3-strand or add anchor swivel? Northeaster Gear & Maintenance 2 06-16-2010 08:12 AM
Chain anchor rode length braidmike Gear & Maintenance 20 10-24-2009 11:06 PM
Anchor Rode to Chain attachment weephee General Discussion (sailing related) 4 08-24-2009 12:56 PM
anchor rode and chain Rockter Gear & Maintenance 10 04-01-2008 01:29 PM
Storing Rope & Chain Anchor Rode weewillystine Gear & Maintenance 2 04-22-2003 01:39 PM
SEO by vBSEO 3.6.1
