Question of spinnaker bail strength - SailNet Community
post #1 of 4 Old 04-06-2012 Thread Starter
brehm62's Avatar
My 20' boat has a spinnaker bail on the masthead. I don't have a spinnaker but I was planning on making a drifter.
The drifter would be about 180 sq ft made from 1.62 ounce ripstop nylon. I had thought that I would just rig it to the spinnaker bail. However, later I started to wonder if the spinnaker bail could take side loads since a spinnaker would typically have just forward loads.
The bail appears to be 6mm (just under 1/4") and projects about 1 1/2". It's about 1 1/4" wide.
My main concern was that it might crack the cast masthead with side loads. However, I'm now thinking that the attachment for the bail does not appear weaker than the attachment for the stay pins. This would suggest that it could indeed take the loads from a drifter.
So, I was just wondering if this seemed rational or if I was overlooking something.
brehm62 is offline
post #2 of 4 Old 04-06-2012
Re: Question of spinnaker bail strength
It will be fine.. Dont' forget you can get up to a beam reach with a standard symm spinnaker so side loads are quite common. That fitting looks as robust as any and you're not talking big loads anyway with that small a sail.
Go for it!
Faster is offline
post #3 of 4 Old 04-06-2012
pdqaltair's Avatar
Another way to think about it is "how much sideways force could I apply before the masthead was near the water?" On a 20-foot boat, not a lot. Perhaps 500 pounds. I used 1/4-inch line and a bullet block on a 27-foot catamaran for years.
Code zeros are a whole different matter. A the tight luff drives the forces way up. The reacher set-up on the above boat was separate and MUCH stronger.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #4 of 4 Old 04-06-2012 Thread Starter
brehm62's Avatar
My design load was 210 lbs. This would be 20% of the strength of the fabric. But even that would require an 18 mph wind and I can't imagine having a drifter up under those conditions. I would step down to the standard jib. The more typical condition with a 5 mph wind would only be about 16 lbs of force on the sail. I would imagine I would drop down to the Genoa about about 10 mph.
My regular jib has a cable in the luff. But, that would seem to be overkill for ripstop nylon fabric. I was just planning to use a 1/8" cord in the luff so, no, it wouldn't be tight like a code 0.
brehm62 is offline
spinnaker question YARDPRO Gear & Maintenance 6 11-19-2010 04:26 PM
spinnaker question for ranger 26 rgberry53 General Discussion (sailing related) 6 12-23-2009 03:11 PM
Masthead Spinnaker bail attachent coolcarls Newport 1 05-22-2008 10:26 AM
Spinnaker Condition Question AlbertJ Racing 10 02-21-2008 05:00 PM
Question for sailmaker: Leech strength RichH Gear & Maintenance 0 09-18-2002 09:09 PM
