Cleaning the boat - SailNet Community
post #1 of 9 Old 04-06-2012 Thread Starter
brehm62's Avatar
Cleaning the boat
In another thread someone talked about seeing boats with mold on them. So, I thought I might post some pictures of what could be a worse case. This isn't mold; these are lichens growing on the Gelcoat. Yes, it looks pretty bad. The first instinct would probably be to use a pressure washer. But, I can tell you that a pressure washer will only remove about 2/3rds of what is there; it will not get it clean.
brehm62 is offline
post #2 of 9 Old 04-06-2012 Thread Starter
brehm62's Avatar
Re: Cleaning the boat
If you remove the most obvious lichens then you still have a dark coating left behind that looks a lot like mold.
brehm62 is offline
post #3 of 9 Old 04-06-2012
SV Skalliwag #141
brokesailor's Avatar
What's a lichen?
brokesailor is offline
post #4 of 9 Old 04-06-2012 Thread Starter
brehm62's Avatar
But with a little dishwashing liquid and a bit of bleach, it does come off with a brush. It is also on the mast but it wipes off of that too.
brehm62 is offline
post #5 of 9 Old 04-06-2012 Thread Starter
brehm62's Avatar
Originally Posted by brokesailor View Post
What's a lichen?
They commonly grow on trees and rocks. Like these:
brehm62 is offline
post #6 of 9 Old 04-06-2012
Lflowers230's Avatar
I used to work on a tow boat. A weekly ritual was to wash the entire vessel. Dawn with bleach and water in a pump up pressure bottle like the ones used for pesticide is what we used. It kept the paint bright white until warmer weather allowed us to chip and repaint the entire boat. It works well when/where you're allowed to use it.
Sadly, at my slip, any chlorinated chemical is prohibited.
Lflowers230 is offline
post #7 of 9 Old 04-06-2012
Barquito
Barquito's Avatar
Would bleach do anything to painted deck, or (dark) painted topsides?
Barquito is offline
post #8 of 9 Old 04-06-2012
I think we used a latex paint on the towboats. As far as damage to the paint, IDK. If so it wasn't noticeable because we repainted every spring. We would take our solution and spray everything. Where there was stuff growing, it would change color. We'd then take flat broom looking scrub brushes and go to work. The growth came off quite easily and we'd rinse.
I could see a strong concentration maybe having a drying effect but not sure. I flunked college chemistry.
post #9 of 9 Old 04-06-2012 Thread Starter
brehm62's Avatar
I wouldn't think you would have that kind of trouble with a painted surface. Gelcoat is a pain because it is porous. But, you know what they say, test a little in an out of the way place before you expose the whole area.
brehm62 is offline
cleaning boat fenders jaybird2719 SailNet FAQ 7 03-17-2011 07:32 AM
Cleaning a Boat on a Mooring - What do you do? ryanjdillon Gear & Maintenance 10 01-21-2011 09:00 PM
Cleaning bottom by heeling boat over. zz4gta Gear & Maintenance 13 07-06-2009 11:58 AM
Boat Spring Cleaning Ideas? Joesaila Gear & Maintenance 11 02-27-2009 06:25 PM
End of season boat cleaning kimbersleep Gear & Maintenance 7 08-27-2008 03:08 PM
