Shore power question - SailNet Community
post #1 of 3 Old 04-08-2012 Thread Starter
NewportNewbie's Avatar
Just moved into a slip with shore power. The boat does not have an AC to DC converter. I do have a Newmar ABC series battery charger system. Can I run the boats electronics off of batteries WHILE they are charging thus indirectly running the boat off of shore power? I don't have a ton of electronics. Actually the ONLY thing I would run off of the batteries while they are charging would be a radio. The other thing I could do would be to get an AC to DC converter and run off of that while connected to shore power. Maybe I could plug that power source into to main electrical panel as another power source?
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 3 Old 04-08-2012
JimsCAL's Avatar
Re: Shore power question
No reason why you can't use your radio (and lights, etc.) while at the slip with the charger running. No different than using them while the engine is running and charging the battery. Note that the charger IS an AC to DC converter!
JimsCAL is online now
post #3 of 3 Old 04-08-2012 Thread Starter
That's what I was thinking. Just didn't want to do anything stupid.
Shore Power Question mobilchuckje Cruising & Liveaboard Forum 12 01-21-2010 10:41 PM
Shore Power Question mauidan15 Gear & Maintenance 11 01-24-2008 07:57 PM
Shore Power Question studwellboiman31 Gear & Maintenance 7 12-29-2007 05:05 PM
shore power dumb question wchevron General Discussion (sailing related) 11 10-19-2007 09:45 PM
Shore power question Omatako Gear & Maintenance 23 04-13-2007 11:33 PM
