Where is your spinnaker pole??? - SailNet Community
 2Likes
post #1 of 32 Old 04-07-2012 Thread Starter
NewportNewbie's Avatar
Mine is down below now...not a great place. It was on the deck and in the way. I am looking for some ideas on the best place to store it out of the way and still on the boat if I ever need to use it. I think I will put a cover on it and then get a pair of stanchion mounts and mount it to the stanchions on the bow of the boat. Here is a pic of where it is now...
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 32 Old 04-07-2012
jppp's Avatar
Re: Where is your spinnaker pole???
Mine is in the garage.............for now.
1985 C&C 35 MK 3
jppp is offline
post #3 of 32 Old 04-07-2012
Mobnets's Avatar
Stanchion Mounts are the way to go for spinnaker poles and whisker poles IMHO.
Mobnets
1973 Paceship 32/28 "Westwind"
Mobnets is offline
post #4 of 32 Old 04-08-2012
Cruiser2B's Avatar
our lies on the forward starboard deck....stays out of the way. probably gonna remove it as i have an asy spinnaker and usually dont sail dead downwind...
i have seen some that store against the mast..i like that setup myself
svsalacia.blogspot.com
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #5 of 32 Old 04-08-2012
Senior Moment Member
SloopJonB's Avatar
Get a chock for the aft mount and place it alongside the toe rail - it's out of the way there and doesn't create windage the way mounting it on the stanchions does.
Faster likes this.
SloopJonB is online now
post #6 of 32 Old 04-08-2012
Mermaid Hunter
SVAuspicious's Avatar
I have a single ended pole that mounts vertically on the mast. Very nice for both sym and asym chute and as a crane.
SVAuspicious is offline
post #7 of 32 Old 04-08-2012
Somewhat Senior Member
mgmhead's Avatar
On my previous boat the pole was mounted on the deck with the stern ward chock outboard just inside the toe rail. Not bad but often in the way.
My current boat has the pole mounted on the stanchions, much better but not perfect.
While I've never had the set-up myself, when racing on a friends boat the pole was mounted on the mast. I thought that the best arrangement I've ever seen.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #8 of 32 Old 04-08-2012
HANUMAN
RobGallagher's Avatar
Honestly, if you are not using it, take it home. Makes life easier until you are ready. I kept mine on board the first year or two "just in case", kind of a waste of space.
I ended up converting to a cruising chute set up and even that didn't get much use as I sail short handed most of the time.
RobGallagher is offline
post #9 of 32 Old 04-08-2012
Lake Superior Sailor's Avatar
I stanchion mounted both spinnaker pole & boomstay poles they , beef up the safety lines & look good in the pictures!..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #10 of 32 Old 04-08-2012
SloopJonB's Avatar
Whutz a "boomstay pole"?
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 10:39 AM
Spinnaker Pole DropTop General Discussion (sailing related) 8 08-27-2009 11:59 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
Spinnaker Pole Set-Up Dan Dickison Racing Articles 0 06-30-2002 08:00 PM
