Should I raise my genoa with an extension? - SailNet Community
 6Likes
post #1 of 23 Old 04-09-2012 Thread Starter
rhr1956's Avatar
Currently I attach the tack directly to the hardware on the deck. I have about 18" available at the top of the forestay to raise the sail higher. All I need is a short piece of sta-set to make the extension between the tack of the sail and the connecting point at the bow. Would I get any appreciable improvement by doing this?
rhr1956 is offline
post #2 of 23 Old 04-09-2012
One of None
deniseO30's Avatar
Re: Should I raise my genoa with an extension?
You would have better vision, less chafe on the bottom, Doubt that it would improve sailing much enough to notice.
Tempest likes this.
My last project!
deniseO30 is offline
post #3 of 23 Old 04-09-2012
Tim R.'s Avatar
A lower sail will generally give you better performance if at deck level. The wind is better contained in the sail.
If you are using a furler, you better ensure that the halyard is the correct length when the sail is raised or you will get halyard wrap.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #4 of 23 Old 04-09-2012 Thread Starter
rhr1956's Avatar
No furler...hanked on. I could use some improved visibility forward. My jib's foot is cut upward enough that I can see under it. The genoa's foot is cut much flatter and makes it a b@#$h to see what I'm about to run into.
rhr1956 is offline
post #5 of 23 Old 04-09-2012
One of None
deniseO30's Avatar
I've a friend that had a "deck sweeper.. was a sight to behold. but hard to see under LOL
My last project!
post #6 of 23 Old 04-09-2012
jsaronson's Avatar
If you raise the sail you need to move the genoa car aft, otherwise you tension the leach. Looks like you have a fixed eye, so you should not raise the sail. On 420s we had a short chain to adjust leach tension. A few inches of chain made a difference on a much smaller boat, so I'm sure a foot would really adversely affect your performance.
jsaronson is offline
post #7 of 23 Old 04-09-2012
Senior Slacker
SlowButSteady's Avatar
A headsail close to the deck will benefit from the "end-plate effect" when sailing relatively close to the wind, and it will keep the moment arm of the sail as low as possible (so the boat won't heel quite as much). Off the wind, neither of these effects will matter much.
A headsail with a short pendant on the tack will give the helmsman more visibility at the cost of a bit of efficiency (for the reasons above). Unless you're racing, the gain in visibility is usually worth the very slight loss in drive.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #8 of 23 Old 04-09-2012
Senior Moment Member
SloopJonB's Avatar
Your jib isn't a deck sweeper so it isn't getting much, if any end plate effect from the deck. Raise it and get the visibility. I did this on my old 20' and it had no effect on performance. If you have a stretchy luff you can use a small dinghy size tackle as a "tack pennant" to enable you to stretch the luff when the sail is hoisted to the masthead block.
SloopJonB is online now
post #9 of 23 Old 04-09-2012
CaptainForce's Avatar
............. If you have a stretchy luff you can use a small dinghy size tackle as a "tack pendant" to enable you to stretch the luff when the sail is hoisted to the masthead block.
I know this is a trivial point, but I'll suggest that it's a "tack pennant".
SloopJonB likes this.
CaptainForce is offline
post #10 of 23 Old 04-09-2012
Senior Slacker
I looked around the Web a bit, and apparently both terms (pennant or pendant) are used for such a thing. However, a thin tapering flag is only referred to as a pennant (from the Middle English word, penon, which was in turn derived from the Old French word pene, for feather). The term pendant seems to be derived from Old French for something attached to a short line or chain (as in a piece of jewelry). So the latter is probably more correct.
Pendent is an adjective referring to the condition of hanging (e.g., a lamp could be pendent, from a pendant)
(There will be a quiz next week. Bring a short-form Bluebook and a pen.)
Tiller extension adapter for old & new extension CalAlida General Discussion (sailing related) 2 07-02-2010 09:48 AM
DIY tiller extension? AllThumbs Gear & Maintenance 2 03-21-2009 03:17 AM
Shaft extension jr438234606 Gear & Maintenance 7 06-07-2008 02:28 AM
forestay extension papasailor Gear & Maintenance 6 06-02-2008 09:10 PM
Can't come about/rudder extension? williamtaylor General Discussion (sailing related) 15 08-12-2006 03:07 AM
