Old 11-30-2003
edr1 is on a distinguished road
Beneteau Lewmar portlight leak
The portlights are Lewmar old standard. They are still leaking after I replaced the rubber seal and the o-rings. I did everything BUT THEY ARE STILL LEAKING.
Any suggestion?
Eduardo
Old 09-28-2009
Tcriste is on a distinguished road
I have the same problem. The outer frame is 2 parts and there is a small piece of rubber between them - these seem to deteriorate over time. I removed the inner frams and had my wife pour water over the portlight with the portlight locked closed - with new gaskets. R\I could see the water coming in right at the location where the 2 pieces meet. The small rubber piece does not appear to be a spare part.
Remove the inner frame and see if that is where water comes in. I applied some silicon and that worked for awhile but erodes away - you can't put much on there.
Servicing older lewmar winch zeilfanaat Gear & Maintenance 3 06-06-2011 02:58 PM
Club Beneteau Florida Invitation Jeffrey123 Gear & Maintenance 0 09-11-2004 12:42 PM
Beneteau Club FLorida Invitation Jeffrey123 General Discussion (sailing related) 0 09-11-2004 12:40 PM
Lewmar opening port leak ref_123 Gear & Maintenance 4 09-29-2003 09:36 AM
Hunter vs. Beneteau PASailor Boat Review and Purchase Forum 10 11-12-2000 07:04 PM
