Like Tree1Likes
  • 1 Post By SVAuspicious
  #1
Old 04-11-2012
Geoff54's Avatar
Geoff54 is on a distinguished road
BVI Waypoints
I have created a .gpx file of BVI waypoints that I am happy to share as long as I can find a couple of volunteers to check it first.
I left my handheld GPS without power over the winter and lost all the waypoints that I had accumulated. I was going to download a set of BVI waypoints from Fine Edge but it doesn’t look like they offer them anymore – so I keyed them into EasyGPS and uploaded them to my handheld. They correspond to the waypoints on the Fine Edge map (as provided by Conch) and probably the guide as well but as I use the Nancy & Simon Scott Cruising Guide, I can’t be sure. I’m happy to make them generally available once they have been checked and corrected.
If you are prepared to do this I will email the file to you and I can also scan the list from the map if you need it. There are 144 waypoints on the file.
Warning, I am going to insert a couple of deliberate errors to make sure it has been checked properly.
Anyone interested?
  #2
Old 04-12-2012
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious will become famous soon enough
Re: BVI Waypoints
You might want to look at the wayppoints on BVIpirate.com.
DRFerron likes this.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
  #3
Old 04-12-2012
sck5 is on a distinguished road
Re: BVI Waypoints
you are going to insert a couple of deliberate errors?
Let me know when you correct them and then maybe I will be interested. Til then, I dont want to put waypoints I know are wrong on any gps or computer I own.
  #4
Old 04-12-2012
Geoff54's Avatar
Re: BVI Waypoints
Thanks. I’ve had the BVIpirate list saved for some time although I have never converted it to .gpx or loaded it.
I like the Fine Edge waypoints because they are a comprehensive set that correspond to routes on their map and make route planning easy. I have used them a lot but only entered in the ones I planned to use that day – having them all downloaded will save time and effort.
Let’s face it, you don’t really need GPS in the BVI, but I like to have the route entered to make it easy to check where I am, at a glance. I thought others might like to have them as well but I didn’t want to risk someone using them unless they had been thoroughly checked. If no one wants to, that’s fine, I’ll just double check them against the chart as I use them.
  #5
Old 04-12-2012
Geoff54's Avatar
Re: BVI Waypoints
That's the whole point of asking for someone to check them. The deliberate errors are to make sure thay are actually checked. I guess you'll just wait until someone else does the work for you. I suppose that I shouldn't be suprised at that attitude.
You may post attachments
You may edit your posts
Waypoints of oil/gas structures in North Sea? patrickstickler General Discussion (sailing related) 3 03-09-2011 10:37 AM
Downloadable Waypoints NormR General Discussion (sailing related) 0 11-04-2004 05:02 AM
SEO by vBSEO 3.6.1
