Coffee Maker - SailNet Community
 9Likes
post #1 of 86 Old 04-12-2012 Thread Starter
nauticalrich's Avatar
Coffee Maker
What do you use to make coffee on the boat, mainly at anchor?
nauticalrich
1985 31 Oday
Bridgeport, CT
nauticalrich is offline
post #2 of 86 Old 04-12-2012
Jetexas's Avatar
Re: Coffee Maker
Percolator on the alchohol stove at anchor. Not the best.
Normal 4-cup coffee maker when at the marina.
Jetexas is offline
post #3 of 86 Old 04-12-2012
TQA
Bombay Explorer 44
TQA's Avatar
Re: Coffee Maker
I use a filter cone and unbleached paper filters. Use water just below boiling point. Folgers Columbian or Leader Price Columbian ground coffee.
Produces the essential morning nectar of the gods.
A percolator boils the coffee ugh!
TQA is offline
post #4 of 86 Old 04-12-2012
Re: Coffee Maker
we just use a small drip style filter over the cup or thurmas ..
teaspoon of coffee then just pour boiled water throw it .
it keeps the grounds out , we used to use a coffee press from akia
Sunday Driver is offline
post #5 of 86 Old 04-12-2012
Battered and Bruised
Silvio's Avatar
Re: Coffee Maker
A french press on the hook and electric drip at the dock. I used to have a 12v electric drip but it was small and the press is easier on the hook, imho.
SV S.S.R.I
It's my happy pill
Silvio is offline
post #6 of 86 Old 04-12-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Coffee Maker
Depends on how you like your coffee. You will never convince an espresso lover that percolators or filters make anything other than undrinkable muck.
If otoh you do like espresso then only a bar pump machine will be ultimately satisfactory. thse however are not really suitable for the restricted power capacity of your average sailing boat. Best alternative is probably the stove top espresso pot a'la Bioletti
or failing that then the previously mentioned French press.
So many coffee threads have come before and you might want to have a read of some.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #7 of 86 Old 04-12-2012
Well-wisher
Re: Coffee Maker
French press. I liked it so much on the boat that we only use the same at home. Camp-mor or Amazon.com sell plastic ones that are easy to clean, durable and have an insulating sleeve.
pschoonveld is offline
post #8 of 86 Old 04-12-2012
jimrafford's Avatar
Re: Coffee Maker
French press most of the time if it's just the 2 of us but quantity is limited. If we have guests I have a coleman gas stovetop drip that makes 12 cups.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #9 of 86 Old 04-12-2012
Sundance 23
carl762's Avatar
Re: Coffee Maker
Used a french press for a while, but somebody stole it out of my little gear box in the cockpit. Made great coffee.
Now using a Percolator, and yup, it's not good coffee.
Going to dig the Melita drip maker out of the campbox and use that. Always makes an excellent cup of coffee and takes up little space.
Water is Life
carl762 is offline
post #10 of 86 Old 04-12-2012
Siamese's Avatar
Re: Coffee Maker
I boil water in a teapot over our propane burner and pour it into a filter cone with fresh ground coffee.
Siamese is offline
Coffee in the Sea of Cortez Controlled Jibe Central America 19 01-11-2012 01:26 PM
Coffee mcain Provisioning 109 06-29-2010 03:12 PM
What do you use for a coffee pot? Garffin Gear & Maintenance 59 12-14-2009 12:01 PM
Captains Coffee bwalker42 Provisioning 26 08-02-2008 12:56 PM
Best Coffee Maker scurvy General Discussion (sailing related) 33 09-04-2007 06:30 AM
