  #1
Old 04-12-2012
Da Most Educated Red Neck
rockDAWG is on a distinguished road
46cfr p7- boundary lines
"90 days of which must be gained seaward of the boundary line."
What does this mean? TIA
  #2
Old 04-12-2012
boatpoker's Avatar
boatpoker is on a distinguished road
Re: 46cfr p7- boundary lines
Inland navigation rules vs. International Collision Regulations
Dirt People Scare me
  #3
Old 04-12-2012
Argyle38's Avatar
Argyle38 is on a distinguished road
This is the COLREGS line. Typically it means that you are in open water and are no longer under inland waterways rules, as mentioned. If you look on a chart that contains an inlet to the ocean, you typically see a line that goes across the entrance labeled "COLREGS Demarcation Line". Beyond this line you are to seaward of of the boundary line and you can log that time toward your 90 days required for that part.
Most protected bays and waterways (maybe all, but I'm not sure) are inside of the COLREGS line. Chesapeake, Long Island Sound, Cape Cod, etc. are all inside the COLREGS line.
S/V Argyle
Downeaster 38 #40
You may post attachments
You may edit your posts
Size & Type: Dock lines vs. Mooring lines JordanH Gear & Maintenance 23 05-19-2011 10:29 PM
Off her lines? L124C Gear & Maintenance 10 08-20-2009 02:34 AM
Off her lines? L124C Gear & Maintenance 1 08-17-2009 11:39 AM
Lines aft sneuman Gear & Maintenance 6 09-29-2003 09:10 AM
Lines Led Aft Sue & Larry Gear and Maintenance Articles 0 10-28-2001 07:00 PM
SEO by vBSEO 3.6.1
