Not Sure Wich Winch to use - Page 6 - SailNet Community
 8Likes
post #51 of 53 Old 05-23-2012
Re: Not Sure Wich Winch to use
Faster,
If that is going to be a permanent piece of hardware, you really need to switch it out for a standard block. It looks like you are using a Ronstan 6710 or something in that size range, and they are just not strong enough to handle the loads a turning block will see. It isn't the static loads that will break it, but a shock load from hitting a wave, or when the sail fills suddenly. If I am right about which block that it, it is rated to only about 2000lbs MBS, compare that to a Harken 57mm black magic rated to 3500lbs or a high load block rated to 5000lbs.
Itgoshen,
Please, please, please go hire a local racer/boat bum to go out with you for an afternoon. Even if they aren't instructors, a lot of the problems you are having just require a few minutes of work from someone who is knowlagable to get you guys in much better shape. At least around here I can grab a local boat guy from a couple of beers, and a promise to take his girlfriend out with us.
If you are in Beaufort SC, in fact just take a walk down to Beaufort yacht club and ask around, you can probably get a couple of guys to help you out for nothing except a promise to go sailing. I am pretty sure there is also a college team that sails out of there, and they could be a good resource for someone that can help you out.
You have a beautiful boat, and it is very well equipped, but poor rigging can not only make sailing more dangerous for you, it can also seriously damage the boat.
Stumble is online now
post #52 of 53 Old 06-26-2012 Thread Starter
First String
Thanks, I have moved from the mooring field over to the docks at Port royal Landing marina. Now I'm getting a multitude of help. Thanks so much for pointing me in the right direction. this has been a great help to me learning the ropes. Thanks to you all,
HDChopper likes this.
ltgoshen is offline
post #53 of 53 Old 07-30-2012
jzk
I see from another post here that you owned an Irwin 38 aft cockpit. Is that correct? I have one, and have only found one other person who has owned that boat.
Does this look like your Irwin?
Irwin 38
webguy262 is offline
Winch handle in winch glassdad General Discussion (sailing related) 19 05-11-2011 06:10 PM
New Winch - Which One ? mjak42 Gear & Maintenance 0 05-04-2010 09:18 AM
you CAN use the winch deniseO30 herSailNet 31 10-30-2007 09:40 PM
Winch Way? garycalvinsmith Gear & Maintenance 1 09-12-2006 09:06 AM
which winch?? maestro Racing 2 03-30-2004 02:47 AM
