Prescription sunglasses for astigmatism - Page 2 - SailNet Community
 1Likes
post #11 of 29 Old 04-19-2012
Re: Prescription sunglasses for astigmatism
Maui Jim "Island Time" frames.
"Just call me TB"
capttb is offline
post #12 of 29 Old 04-19-2012
s/v Ilya
arknoah's Avatar
Originally Posted by SkywalkerII View Post
Maui Jim
The first and last choice. You will love them.
I've had two pair, titanium frames, light, clear. Mine are progressive lenses to correct astigmatism and farsightedness.
Pricey but worth it.
Look for a local optometrist who is a dealer.
Skywalker
T27 249
Since you mentioned that you wanted wrap around frames, I just wanted to comment that for many with progressive lenses, wrap arounds are difficult if not impossible to do because the different strengths throughout the lenses aren't uniform, and vision to the side is often distorted. You may want to check that out carefully.
Just saying....
Ilya's Adventures:
____________________________
And straight on 'til morning
arknoah is offline
post #13 of 29 Old 04-19-2012 Thread Starter
thanks for the info.
wretchedsailor is offline
post #14 of 29 Old 04-19-2012
wretched-
" I have a fairly substantial astigmatism (-3.25 in each eye)"
At least in the US, astigmatism is measured by DEGREES, as in rotation of an axis. Your main visual correction is measured as a plus or minus diopter figure, and a -3.25 would mean you are somewhat nearsighted and probably can't see faces clearly at 25 feet. An rx of "-3.25 x 180" would indicate the same diopter required--but an astigmatic axis of 180 degrees. If your Rdx does not have the "x ###" after the diopter, you have not been given an astigmatic correction.
So are you absolutely SURE that rx is just for astigmatism??
That's got nothing to do with astigmatism, that's just called needing glasses.
There's no perfect solution, you simply need to TRY things and yes that will waste some money but that's the only way to find out what works for you. Sailing? Contact lenses can be great, they're nearly "air" these days and when fit properly, you can't feel them. There are limited options for correcting astigmatism on contacts though. Contact lenses also dont have any problem with salt spray or rain, you just use plain saline or lubricant drops if/as needed. OTOH sunglasses will get salt spray on them, and if you clean that off without fresh water and a clean cloth, you'll destroy plastic lenses pretty quickly. Glass lenses resist way better.
If you do get lenses made up for your Rx...sometimes you get what you pay for. Every year that "chains" are surveyed, they get rated for not getting accurate prescriptions compared to independent optometrist offices. And the independents often can match prices, if you just mention that you'd LIKE to do business with them, but the prices...
FWIW in the US lenses are only made to the nearest 1/4 (0.25) diopter, so a tolerance that is 1/8 off your exact rx is considered as good as it gets. The axis for the astigmatic correction depends not only on how the lenses are made--but also very much on how carfully they are fitted (rotated) in the frame. So there again, a fast chain shop often doesn't do it as well. I'm sure there are some that do--but the surveys say "not likely".
What do I wear? Sometimes contacts, sometimes glasses. On the longest brightest days? I'd rather wear contacts, because I've got some incredibly dark sunglasses I can use with them, that would mean too many pair$$ with an RX. And some that just can't bemade in an Rx at all, like gold-flashed glacier glasses, that block all IR and UV.
hellosailor is offline
post #15 of 29 Old 04-19-2012
Daniel - Norsea 27
Rhapsody-NS27's Avatar
My first pair of prescription sunglasses were Oakley. Now I have a pair of Ray Ban. The oakley's were wrap around style, the RB I have now are not. I can see better with my RB than regular glasses and they're both the same prescription. If I remember right, I have -3.75 for each eye.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #16 of 29 Old 04-19-2012
Owl
-OvO-'s Avatar
I have had the oakleys for five years and love them. I have a slight astigmatism in one eye, not so bad as yours.
-OvO- is offline
post #17 of 29 Old 04-19-2012
Hellosailor thanks for clearing up the astgmatism deal. I used to work for a Contact Lens Mfr. I was kind of scratching my head about the -3.25 astigmatism (aka Toricity) too.
I had a buddy who got his lenses from the local dive shop. They make them for dive masks. He just puts those corrective lenses on his favorite non-prescription sunglasses. Says they work Great!!
Bamazeb is offline
post #18 of 29 Old 04-19-2012
chef2sail's Avatar
Since you mentioned that you wanted wrap around frames, I just wanted to comment that for many with progressive lenses, wrap arounds are difficult if not impossible to do because the different strengths throughout the lenses aren't uniform, and vision to the side is often distorted. You may want to check that out carefully.-arknoah
Thats why I recommend the Rudy Projects, they are able to handle the different curvatures and lenses for me. They varied the matierial of my lenses to help allieviate this and it worked out perfectly,
They also use Carl Zeiss lenses.
Dave
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #19 of 29 Old 04-20-2012
Oakley all the way, a close face hugging frame. I've tried Rayban etc, but the lens curve always messes with straight lines, looking at a tile floor gives me a headache! I can't imagine sailing would be much easier than riding with them. The oakleys get my vote, either replaceable lenses(flak jacket with the larger lens) or the full framed ones.
A good glasses shop will have a book with Oakley's specs, and send them away for the lensmaking to Oakley. Part of that spec is the curvature, and the maximum prescriptions. I have some astigmatism, and 2.25 Rx. I was still able to find a suitable and comfortable frame.
Jgbrown is offline
post #20 of 29 Old 04-20-2012
I have Rudy Project sunglasses and absolutely love them. They were pricey, but that's what FSA accounts are for. Rudy Project makes at least one set of frames specifically for sailing (they float, among other features). I have perfect vision all the way around -- far more peripheral vision than I do with my regular glasses. Regardless of what brand you go with, be sure to get a polarized lens, not just a tinted one ( and you'll probably want some anti-glare, anti-scratch, etc coatings).
1979 Gulfstar 37 Laissez Faire
rmeador is offline
Sunglasses for the Bahamas cherokeelullabyII Cruising & Liveaboard Forum 13 11-06-2011 07:05 AM
Sunglasses goduke Gear & Maintenance 24 05-27-2009 03:27 PM
Prescription Sunglasses Albie Gear & Maintenance 41 05-19-2009 08:48 PM
Sunglasses funkychicken911 Gear & Maintenance 4 12-29-2002 11:19 AM
