Re-Naming A Boat - SailNet Community
 2Likes
post #1 of 12 Old 04-23-2012 Thread Starter
casey1999's Avatar
Re-Naming A Boat
My boat has had several names over the years. I was thinking about re-naming her, but am afraid about any bad luck it might bring.
Would it be ok to write the previous names on the stern in small (1-inch high) letters with the new name in larger lettering. Would this appease the Poseidon or upset him?
casey1999 is offline
post #2 of 12 Old 04-23-2012
Irunbird's Avatar
Re: Re-Naming A Boat
uhh, I don't know... Isn't that a little like making a mark through the tatooed names of old girl friends and getting a fresh tatoo of the current girl on your arm? We just bought an Olson 30 and I'm planning on doing plenty of ocean sailing (up/down the coast, and a possible double-handed venture to Bermuda), so I'm personally not taking any chances. This is what I'm going with before renaming her properly- 48 Vigor's Interdenominational Boat Denaming Ceremony
jrd22 likes this.
Irunbird is offline
post #3 of 12 Old 04-23-2012
Nooooooooo! That will upset him for sure and will absolutely positively bring 100% certain doom!
ALL references to old names have got to go.
Here, look it's even on the Internet so you know it's true: Renaming Your Boat - BoatSafe.com
xymotic is offline
post #4 of 12 Old 04-23-2012
Courtney the Dancer
jrd22's Avatar
When you're dealing with Gods, make sure you don't skimp on the quality and quantity of champagne (see above referenced Vigor's ceremony). All references to past names must be removed from the boat and they should never again be spoken while aboard. To do so is at your peril. Many have chosen to ignore these well known truths, but they've all suffered terrible fates.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 12 Old 04-24-2012
is Awesome!
Send a message via Skype™ to DavidB.UK
I think on this thread one can only express their personal beliefs on the subject.
For my 2peneth I think the honour and privilege of naming a baot belongs to those who commission the build.
I have only been able to buy 2nd hand boats so far, but I do look forward to the day when one day I can name my first Oyster!
__________________________________________________ ______________
However, I believe that a case could be made that the changing of name has nothing to do with the gods but the subsequent 'bad luck' is nothing more than law of attraction manifesting mis-fortune because you have the idea of 'bad luck' festering in the back of you mind...
And so because (on some level) you are thinking about mis-fortune, so shall you come to experience it...
DavidB.UK is offline
post #6 of 12 Old 04-24-2012
Scrape it all off and put the new name on. Screw the jinx it's all in your head!!! If you sail stupid and sink is that a jinx or if you sail with total awareness and find your port is that luck?
DavidB.UK likes this.
Shemlock is offline
post #7 of 12 Old 04-24-2012
Cruiser2B's Avatar
While I usually tend to agree with your type of thinking and was going to take that route. I could not do it. We followed the de-naming procedures of John Vigor as well. It was actually a good time. Have fun with it, Isnt that what the boat is for?!
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #8 of 12 Old 04-24-2012
Re-name her- get lots of champaign and friends and enjoy the ceremony. I did ours on the trailer at home and had the party oops ceremony at the dock when we put her in the water.
H and E is offline
post #9 of 12 Old 04-24-2012
I too believe in keeping the original name. I can do that now because my new boat has a cool name that I like (Oceana) and it has always had the same name since 1938 AND it's welded onto the transom in big block letters. I'm pretty sure it's written in ink in Poseidon's ledger.
But...
My last boat had a stupid name. And it had already been changed before I got it. So in that case, I pretty much HAD to change it because you never know if it was done correctly, and.... well it was stupid so duh!
xymotic is offline
post #10 of 12 Old 04-24-2012 Thread Starter
casey1999's Avatar
Thanks for the good suggestions. I will not paint multiple names on the hull. I am actually thinking about renaming the boat back to its original name. While working on the boat I have found many references to this original name (under sole boards, under cusions, under galley access hatches) so this name was never totally gone from the boat.
I am not generally superstitous, but sometimes when boarding a boat, entering a building, or walking in an area, you get a feeling of past history. You do not want to disturb that history. Maybe it will not bring you bad luck if you do, but you may have better luck if you do not as you have not disturbed the energy of the area or object (I believe boats can store a lot of energy, that is why people are so drawn to boats, and particularly sailing vessels, as large engine can disturb the flow of energy) If I do rename, I will use the proper ceremony.
Re-naming the boat pirateofcapeann General Discussion (sailing related) 130 01-07-2014 11:14 AM
Naming the boat Sublime General Discussion (sailing related) 25 11-29-2010 11:40 PM
Naming a new boat Daveinet General Discussion (sailing related) 5 07-07-2010 12:21 PM
Naming a pre-owned boat Sailgirl2955 General Discussion (sailing related) 15 03-03-2009 12:54 PM
Naming an old boat without a name kpdii General Discussion (sailing related) 10 08-05-2008 03:22 AM
