Teak Cockpit - SailNet Community
 1Likes
  • 1 Post By SloopJonB
post #1 of 6 Old 04-23-2012 Thread Starter
Teak Cockpit
Due to an unusual set of circumstances and a good dealer, I have a choice between two identically equipped Beneteau 41's. The sole (pun intended) difference is one has a teak cockpit and the other doesn't. And I would have to wait 3 weeks for the teak boat and the price difference is around $700.
Opinions?
BCC1 is offline
post #2 of 6 Old 04-23-2012
Senior Moment Member
SloopJonB's Avatar
Re: Teak Cockpit
Opinions?
No teak - put the $700 towards cockpit cushions.
Faster likes this.
SloopJonB is online now
post #3 of 6 Old 04-23-2012
Re: Teak Cockpit
Second that suggestion.
Faster is offline
post #4 of 6 Old 04-24-2012
Tartan 27' owner
CalebD's Avatar
Re: Teak Cockpit
Do you like the look of teak? It takes some work to keep it looking expensive or it turns gray and deteriorates slowly, which some like the look of as well.
I like the look and feel of teak but I could also do without it, if it is not necessary.
You will have plenty of other systems to worry about without exterior teak.
Everybody has one:
CalebD is offline
post #5 of 6 Old 04-24-2012
Re: Teak Cockpit
I have teak seat inserts in my Beneteau and while they are more comfortable than sitting on just glass, you can't see the teak when the cushions are in use anyway. I'd skip the teak--less maintenance that way.
dinodino is offline
post #6 of 6 Old 04-24-2012
jimrafford's Avatar
Re: Teak Cockpit
While the teak looks nice you can't see it thru cushions. The teak is most likely plywood, not solid, and will fail in time. I replaced mine last spring at a cost of $60/ sq ft.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
Wanna do Teak in my cockpit...how much ballpark will it run me??? NewportNewbie Gear & Maintenance 13 10-31-2011 11:09 PM
Oil teak cockpit grate? kwaltersmi Gear & Maintenance 9 04-27-2010 01:56 PM
Teak inlaid cockpit seats drshoe Gear & Maintenance 2 10-01-2009 09:19 AM
Replacing teak flooring in cockpit mikeedmo Gear & Maintenance 0 10-08-2006 06:34 PM
Teak Cockpit Floor Kit Tom Wood Gear and Maintenance Articles 0 01-03-1999 08:00 PM
