recommended book on heavy weather sailing - SailNet Community
post #1 of 7 Old 04-23-2012 Thread Starter
I am looking for a book on sailing in rough weather. Not survival conditions, but rough weather. It seems like all the books on the subject are about deploying drogues in 20' breaking seas. Well, the kind of coastal cruising I do means I will probably never deploy a drogue, or see 20' breaking seas. But I do experience some rough conditions, and the ocassional squall. For example:
I was out today in new York harbor. There was a healthy wind, but nothing crazy. However the swells were short and steep, some breaking, in the 6 - 8' range if not more. It was interesting looking back from the foredeck to the cockpit, preparing to raise the jib, and feeling like I was on a ladder, high up looking down at my father at the helm. Well as our small coastal cruiser heaved up and crashed down, as I got an arm buried in the cold water while readying up the jib at the bow pulpit, we both decided that since it was getting dark and cold, and neither of us had experience in such conditions, it would be safer to turn back.
I recently tried heaving to in my boat. It worked fine, except no matter what I did with the mainsheet and tiller, the boat would sit at well over 90 degrees to the wind, directly abeam to the swell.
Can anyone recommend a book that discusses rough weather sailing in non survival conditions?
peterchech is offline
post #2 of 7 Old 04-23-2012
Senior Moment Member
SloopJonB's Avatar
Re: recommended book on heavy weather sailing
The classic "Heavy Weather Sailing" by Adlard Coles covers a lot more than survival conditions. AFAIK it is still the bible for bad weather sailing.
SloopJonB is online now
post #3 of 7 Old 04-23-2012
The Elephant
smackdaddy's Avatar
This is, by far, the best HWS book I've found:
http://www.amazon.com/HANDLING-STORMS-AT-SEA-Secrets/dp/0071496483
There are many others...all of which I've read ("Storm Tactics" by the Pardey's, "Heavy Weather Sailing" by Coles, etc.) - but Roth's book is the one I'd recommend.
smackdaddy is online now
post #4 of 7 Old 04-23-2012
I like the two choices given above, there are several more. I have a guide by John Neal and Amanda Swan that I picked up at a safety at sea seminar many years ago. There are numerous other books and guides.
I'm not sure any of them will tell you how best to cope with the slop you can get into in New York Harbor with a strong wind against tide, that's just plain nasty stuff. It gets magnified even more at the narrows. I'm sure the SF Bay Sailors and others see that alot too. Those short period waves in the river are worse than larger seas in the ocean. They knock your boat speed down to nothing and can cause you to hobby horse barely making 1 to 2 knots, which will cause you to lose steerage.
I imagine that was what you were doing as you tried to raise your jib into the wind?
It's annoying as hell. You could always try to run with the wind, and beat home at slack...as you know, it's all about the currents up there.
Heaving-to on the river is a little tricky. You've often got a 3-4 knot current and depending on where the wind is coming from it can get shadowed by the buildings, then kick in again in the canyons on either side. It seems to work best for me just using the jib and rudder, with the mainsheet or traveler eased, but not flogging, you're going to end up going where the current takes you.
Good decision going home in that stuff. Sailing is supposed to be fun!
tempest is online now
post #5 of 7 Old 04-24-2012
Cruiser2B's Avatar
I not read the two recommended in above posts but I will.....I have however read Storm Tactics by The Pardeys....i found it very informative.
with that said I dont think any book will be able to replace good old hands on training. Getting out there when the weather is not ideal. it will help you learn how your boat and crew reacts to certain adverse conditions. Last year wife and I got caught out in 50kt+ thunderstorm squalls....learned alot about how my boat and I would handle the situation....it was definitely a hole puckering experience! But we got through it and now can be better prepared for something like it again.
I am however not telling you head out in just plain old dangerous conditions. You'll have to figure that out on your own.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #6 of 7 Old 04-24-2012 Thread Starter
Originally Posted by Tempest View Post
I like the two choices given above, there several more. I have a guide by John Neal and Amanda Swan that I picked up at a safety at sea seminar many years ago. There are numerous other books and guides.
You have described the conditions precisely.
They were bad enough to capsize a powerboat, leading to one drowning...
Boat capsizes in Raritan Bay, killing one, while four are rescued from the water | NJ.com
only one of the survivors was wearing a pfd, the dead man was not...
post #7 of 7 Old 04-24-2012
travlin-easy's Avatar
Lots of great, first-hand information.
Gary
travlin-easy is online now
Heavy Weather Sailing sab30 Seamanship & Navigation 502 01-06-2016 06:30 PM
Heavy weather sailing sailorfrank Learning to Sail 26 09-10-2013 06:32 PM
heavy weather sailing nolasailor Learning to Sail 4 10-10-2011 10:08 AM
Heavy weather sailing in a catamaran seashine Seamanship & Navigation 4 06-13-2010 08:51 AM
Heavy weather sailing - question Trout66 General Discussion (sailing related) 31 11-05-2007 08:20 PM
