Over Powered in 30 knots? - Page 5 - SailNet Community
 5Likes
post #41 of 45 Old 04-25-2012
Barquito
Barquito's Avatar
Re: Over Powered in 30 knots?
I''m not sure if this has been mentioned but if you must sail upwind under jib alone you can usually tack if you foot off just a shy higher than a beam reach, then as you turn the boat into the wind let the jib go and your momentum should carry you through the tack. By pulling the jib tight as you get closer to the wind you are actually worsening your balance by causing more pressure on the jib making it harder to complete the tack.
My understanding is that you have the best chance of getting through a rough tack if you "sail" the jib all the way through. Fall off a little to build speed, then trim in as you head up to close hauled. As you come through let it backwind just a hair, to push the bow onto the other tack.
I think a lot of these pointers in this thread depend a lot on the boat you are on. Some boats sail up wind on jib alone, and some on main alone.
One more point: if you get get knocked to a dead stop head to wind, you could let the boat drift back while steering onto the new tack backwards, sheet in and go.
Valiant 32
Barquito is offline
post #42 of 45 Old 04-25-2012
Originally Posted by Harborless View Post
If you have the money, that place is sweet. Very Spanish Riviera feeling.
That's a stunning yacht club. I looked at a boat that was for sale there, and the owner would sponsor me for membership and a slip if I bought it. The club still had to approve me as I recall, and I think the membership fee was $15k and it was another $1k or so per month for the slip. I went with another boat, but I sure was impressed with EFYC!
dinodino is offline
post #43 of 45 Old 04-25-2012
Closet Powerboater
MedSailor's Avatar
I feel like I should clarify a couple of terms for all. After all, I did introduce the "wear ship" term into the fray.
I will use the original poster's clock analogy to provide the visual for the following definitions.
1. Tack
2. Gybe
3. Wear Ship
4. Chicken Gybe
1.Tack:
If we assume the wind is coming from 12:00 and you are sailing with the bow pointed at 2:00 you are close hauled on a port tack. If you were to swing the bow through the wind at 12:00 and end up closed hauled again with the bow now at 10:00 you have TACKED through the wind and you are now close hauled on a starboard tack.
2. Gybe:
We will continue to assume the wind is blowing from 12:00, only this time the bow is pointed at 4:00. You are on a run (or running before the wind) on a port tack. If you were to swing the bow through 6:00 (DDW or dead downwind) the main and jib would flop over with some force to the other side of the boat. If you continued to swing the bow around to be pointing at 8:00 you have now GYBED and are now on a run on a starboard tack.
3. Wear Ship:
This is another way to tack, where the goal is to get the bow from 2:00 to 10:00 as in example 1. Wind is still coming from 12:00. Assuming you are closed hauled with the bow pointing at 2:00 you are again close haled on a port tack. Your boat doesn't like to go through the wind so instead of turning the bow towards the wind, you turn it away from the wind. Your bow quickly swings through 3,4,5,6 (sails gybe here),& 7,8,9 o'clock and you end up at 10:00, close hauled on a starboard tack. You have just Worn Ship, and gybed around to your new tack.
4. Chicken Gybe:
This is a favorite way to avoid gybing in heavy winds where the force of the boom coming across the boat may do damage. Perhaps the wind is blowing hard (still from the 12:00 direction) and you are too short handed to have someone quickly sheet in, and quickly release the main-sheet for a regular gybe. As in example 2 you are on a port run with the bow facing 4:00. You want to get the bow to face 8:00 but you fear damage if you gybe. You turn the bow into the wind and the bow goes through 3, 2, 1, 12, 11, 10, 9 and you end up with the bow facing 8:00 on a starboard run. You have now completed a Chicken Gybe, as you tacked around through the wind to reach your new downwind course.
I hope that is helpful.
MedSailor
HDChopper likes this.
MedSailor is offline
post #44 of 45 Old 04-25-2012
BostonSailor's Avatar
Good stuff, Med - thx! Hadn't heard chicken gybe but have done a few . Sheeting in a letting out well-timed make a huge difference in controlling a jibe!
BostonSailor is offline
post #45 of 45 Old 11-25-2012
cal22 owner
I had a Ranger 26 that I sometimes sailed with the jib alone, but not in heavy winds. Easing the jib will reduce the lee helm somewhat and also keep the boat on its feet, but a reefed main with a fully let out traveller would have given you a balanced boat, much more control, and way less heeling.
And remember,good judgement comes from experience, and experience comes from surviving bad judgement
dalober is offline
MOB doing 20 knots in 30 knots + recovery AdamLein General Discussion (sailing related) 30 02-11-2012 12:53 AM
wax powered stove lehigh Gear & Maintenance 20 11-17-2011 09:10 PM
Wave Powered !! Freesail99 General Discussion (sailing related) 7 07-14-2008 12:10 AM
Water powered generators rsn48 General Discussion (sailing related) 26 12-18-2007 01:02 PM
gas powered liveaboards... razorseal Living Aboard 11 04-12-2006 02:12 PM
