Battery Interconnects Wire Size With Inverter - SailNet Community
post #1 of 1 Old 05-04-2012 Thread Starter
efiste's Avatar
I have a 1987 Catalina 34. Working on a few electrical upgrades before launching for the spring in the Midwest.
My new 1800 W charger/inverter calls for 2/0 minimum cable from the battery. I have 1/0 between 4 6V T105s in series-parallel. I also have 1/0 from the negative to a battery monitor shunt to the common ground bus bar. With the addition of the inverter, do I need to upgrade the battery interconnects with 2/0 as well or is there some reason this is not necessary (negative side cable distance loss, series-parallel battery behavior)? What about the wiring for the shunt assuming I place the inverter properly to be monitored?
Thanks,
Eric
efiste is offline
wire size from battery to key switch ekenna Gear & Maintenance 12 03-26-2010 12:16 AM
Bonding wire size? sunfishin Electrical Systems 7 01-18-2009 10:25 AM
Lifeline wire size BreakingWind2 Gear & Maintenance 4 10-06-2008 09:15 PM
Wire size between Battery and System? Perithead Gear & Maintenance 5 01-02-2008 01:00 AM
Windlass Wire Size 1970Columbia34 Gear & Maintenance 3 01-01-2007 09:05 AM
