Like Tree2Likes
  #21
Old 05-10-2012
First String
ltgoshen is on a distinguished road
Re: Seatalk help needed badly
O.k got good news!! Last night after reading this post I went home and hooked them all together in a line and hooked them to a 12v battery they all lit up and the readouts are on. Next thing is to take them out to the boat and hook the transducres up and see what happens. Thanks for the help.
  #22
Old 05-10-2012
First String
Originally Posted by old-sailer View Post
I guess I did... one crappy miss-manufactured plug was the problem. I was able to get that reworked myself and I heard beep, beep everywhere as they all turned on. I was so relieved.
Just a note we are close in Hull-Numbers
1981 C&C 30 Mk1
Great boat
  #23
Old 05-10-2012
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
From Raymarine?!? Surely not..
All things considered, Seatalk Original is pretty good at what it does and, now that you've got it going, you shouldn't have any further issues. I notice they don't use the old 4-pin flat-pack connectors on the new flavours... for several reasons.
"Only two sailors in my experience never ran aground: one never left port and the other was an atrocious liar.." - Don Bamford
  #24
Old 05-13-2012
First String
ZCC30641M80G... sort of close.....
Is your engine also fairly new? 204278..
No its the original 2gm 13 HP peeeerrs lik a kitten.
You may post attachments
You may edit your posts
SeaTalk to NMEA mm2187 Electronics 3 09-26-2011 03:42 PM
Seatalk to RS232 to USB to PC SelkirkGrace Gear & Maintenance 3 09-03-2011 02:42 AM
GPX routes into seatalk net?? bhcva Gear & Maintenance 0 04-05-2011 12:10 PM
Question: Autopilot behaving badly okapi3 Gear & Maintenance 13 03-14-2008 07:44 AM
Seatalk failure Mkfcdl Gear & Maintenance 2 09-20-2005 06:05 AM
SEO by vBSEO 3.6.1
