Is this SAFE? - Propane tank - Page 2 - SailNet Community
 1Likes
post #11 of 32 Old 05-06-2012
Closet Powerboater
MedSailor's Avatar
Re: Is this SAFE? - Propane tank
Looks great. My next door neighbor did something similar. A 20lb steel propane cylinder fits perfectly in a milk crate. Same idea but yours looks better.
MedSailor
MedSailor is offline
post #12 of 32 Old 05-06-2012
What kind of alcohol stove did you have? When I bought my Tartan 30 I looked into putting in a propane stove and ran into the same issues you have. I decided to "put up" with the PO's Origo for a season and have had very good results with it. Five years later I would not go to propane on a bet.
I don't have an oven so I can't speak to that, but the stove top is simple and more than adaquate.
fordo is offline
post #13 of 32 Old 05-06-2012 Thread Starter
Future liveaboard
It's a pressurized Shipmate stove and oven. We've used it quite a bit, but it's always tricky and a hassle. We cruised 84 days one summer and it was 'ok', but only just. The burners were strange, and would start to burn out after being on a while. The oven was useless, big hotspot in the middle and not very hot all around. Pumping the tank before each use, then burning a primer cup of fuel, then lighting the hopefully gaseous fuel got old too.
I hear you though. We made the decision and expenditure because we're going to be living/cruising on it soon. We hope to visit many countries and have heard that the alcohol is hard to find and very expensive outside of the US.
So, we're looking forward to easy bleary eyed coffee prep in the mornings and a satisfactory baked pizza here and there. The Seaward range we bought is a beautiful thing... we've tested it in the garage. We'll see how it goes.
SailMonkey is offline
post #14 of 32 Old 05-06-2012 Thread Starter
Future liveaboard
Thanks MedSailor, I appreciate the encouragement!
post #15 of 32 Old 05-07-2012
Originally Posted by OldColumbia View Post
I'd suggest moving the installation inboard of the pulpit and attaching to a stanchion, possibly resting on the gunwale for stability. Mr. Murphy loves anything that can be hit by another vessel, a dock, or some one backing down near your boat. Kinda like transom hung self steering vanes, dinghies on davits, etc.
Agree.
Dick
Flybyknight is offline
post #16 of 32 Old 05-07-2012
Dog Ship's Avatar
I moved my manual electronic propane cut-off switch from behind the stove to a more convenient, yet out of the way spot in the companion way.
I figured if I were to have a fire it will more than likely happen at the stove, my only propane appliance.
So in the event of a fire, as I am flying out the companion way toward the tanks main manual valve I can buy myself a few seconds by hitting the solinoid switch while on my way to the tank at the back of the boat.
I also mounted a fire extinguisher in the propane tanks locker so I can fight my way back into the boat and put the fire out.
Dog Ship is offline
post #17 of 32 Old 05-07-2012 Thread Starter
Future liveaboard
Agree. Dick
Thanks. I like the idea of it out of harm's way. But what about it being essentially in the cockpit then? Wouldn't that have too many potential entryways to the interior? Lockers, pedestal's mount, etc?
post #18 of 32 Old 05-07-2012
On a previous boat we did something similar, made SS tubing 'hoops' that the tanks dropped into at the aft end of the cockpit (attached to the pushpit post). In our case a reverse transom protected them from possibly being 'knocked off' or collided with. Worked well for a lot of years.
Faster is online now
post #19 of 32 Old 05-07-2012
Propane tanks which have a bleed screw on the valve, make it far easier to pour propane from one tank to another.
Just hook them up , put the full one on top, upside down, and the empty one on the bottom , open the valves, then open the bleed screw, until liquid starts to squirt out the bleed screw. Then the bottom one is full.
Brent Swain is offline
post #20 of 32 Old 05-07-2012
I found this when considering a rail mount. I have seen it, but decided to go a different route. It is very sturdy and low profile, might be worth a look for you. I have no affiliation with the product or vendor.
Sure Marine Service, Inc. * Since 1972 * Marine Heating, Air Conditioning, and Galley Equipment
inshallamiami likes this.
baboon is offline
propane tank gregreinhard Gear & Maintenance 5 03-04-2013 01:09 PM
S/S Propane Tank? jppp Gear & Maintenance 11 11-27-2011 05:48 PM
Propane Tank Funsail C30 1 03-12-2011 10:33 AM
Propane Tank Holder TxLnghrn Gear & Maintenance 10 03-12-2009 02:31 PM
Propane tank Irwin32 Gear & Maintenance 10 01-21-2006 06:58 AM
