Is this SAFE? - Propane tank - Page 3 - SailNet Community
 1Likes
post #21 of 32 Old 05-07-2012 Thread Starter
Future liveaboard
Re: Is this SAFE? - Propane tank
Originally Posted by baboon View Post
I found this when considering a rail mount. I have seen it, but decided to go a different route. It is very sturdy and low profile, might be worth a look for you. I have no affiliation with the product or vendor.
Sure Marine Service, Inc. * Since 1972 * Marine Heating, Air Conditioning, and Galley Equipment
I have seen that, thanks!
The AL 6# tank is pricey ($200+), and only 6# of propane...so I went a different direction. The tank I got is fiberglass, and you can see how much propane you have left, and it won't corrode...and was $95. Their bracket is $100, I built this for about $35 all AL and SS. I have to be frugal... I'm not paying the yard the $1000 labor they quoted for putting propane in either!
SailMonkey is offline
post #22 of 32 Old 05-07-2012 Thread Starter
Future liveaboard
Originally Posted by Chris12345 View Post
Well, the positive comment first: I think this setup is safer than ANY propane installation I have ever seen.
The negative: It screams "TRAILER PARK", also more than anything I have ever seen.
LOL. Yeah, a bit, but it's no glamour boat and I think I can shoulder the shame of it. And I must say, I'll take it when it comes with the title of "SAFEST" you've ever seen! Thanks Chris.
post #23 of 32 Old 05-07-2012
Learning the HARD way...
eherlihy's Avatar
It's definitely safer than this;
eherlihy is offline
post #24 of 32 Old 05-07-2012 Thread Starter
Future liveaboard
Think they'll shoot at my boat? Looks like we could have rocket power!
post #25 of 32 Old 05-07-2012
In one of the past issues of Good Old Boat a tank locker was made out of a venier that had fiberglass sandwiched between the layers. It was mounted on the stern attachd to an outboard motor bracket & looked pretty nice.
With your installation, I don't think you need to worry about the tank relief blowing off & filling your boat w/ gas, you're open to the atmosphere. This is in all likelyhood a safer approach when compared to an intergral propane locker.
I'm planning on doing the the same thing because I like trailer parks
Bob
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #26 of 32 Old 05-07-2012
eherlihy's Avatar
Afterburner!
Kind of like reactive explosive armour if someone hits you.
eherlihy is offline
post #27 of 32 Old 05-12-2012
With all the fresh air and moving air, any propane leak should dissipate. I only worry when it is in an enclosed space. Does anyone know what percentage propane/air ratio is needed for an explosion?
nuclear1 is offline
post #28 of 32 Old 05-13-2012
midlife crisis member
AllThumbs's Avatar
If you stand it upright, rather that at the angle of the combing, the propane would be less likely to roll off the bottle and into the cockpit.
AllThumbs is offline
post #29 of 32 Old 05-13-2012
eherlihy's Avatar
Per; Propane Facts | Propane Education & Research Council
Propane has a narrow range of flammability when compared with other petroleum products. In order to ignite, the propane-air mix must contain from 2.2 to 9.6 percent propane vapor. If the mixture contains less than 2.2 percent gas, it is too lean to burn. If it contains more than 9.6 percent, it is too rich to burn.
eherlihy is offline
post #30 of 32 Old 05-13-2012
snake charmer, cat herder
zeehag's Avatar
there are many cruisers here in mexico who managed to sail here from many places including east coast who have their tanks mounted as do you. i dont see any problem with it. smooth sailing.
formosa 41, cruising tropics
zeehag is offline
propane tank gregreinhard Gear & Maintenance 5 03-04-2013 02:09 PM
S/S Propane Tank? jppp Gear & Maintenance 11 11-27-2011 06:48 PM
Propane Tank Funsail C30 1 03-12-2011 11:33 AM
Propane Tank Holder TxLnghrn Gear & Maintenance 10 03-12-2009 03:31 PM
Propane tank Irwin32 Gear & Maintenance 10 01-21-2006 07:58 AM
