Issues with heaving-to - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 05-08-2012 Thread Starter
Re: Issues with heaving-to
Originally Posted by travlineasy View Post
Using the information I garnered from this book I was able to easily obtain the needed 50-degree angle to the waves necessary to heave-to in comfort.
Good Luck,
Gary
Please share, what did you do?
I just bought Adlard Coles' "Heavy weather sailing", I'm in chapter 3, and I need to finish North sail trim too, before I take on another book... haha honestly there are a few more books that I am halfway through but stopped when yet another "must read" sailing book was recommended to me
peterchech is offline
post #12 of 16 Old 05-08-2012 Thread Starter
Originally Posted by sailingfool View Post
You should be able to adjust the hove-to angle by trimming the main.
when going into hove-to, you should fully release the main (what you do with the traveller then does not matter...). When the boat has hove-to, if you slightly trim the main, the boat should turn closer to the wind. If you trim the main too much, the main will cause the boat to tack.
haha "should" is the operative word.
I played with the traveler in the hope that by backing the main a bit to windward using the traveller it would make the boat turn further upwind since the wind would now push it at a greater angle. In fact is made the boat turn more away from the wind, not closer to it. Go figure...
I wonder if keel has much to do with it, since theoretically when hove to there is very little forward motion, and a little to lee, so I imagine the keel would be stalled.
post #13 of 16 Old 05-08-2012
Coles' is one of those that you can read a chapter ( storm) put it down and come back anytime and read another. I found it difficult to read cover to cover the 1st time through it. Which fit's with my reading style of having several books going at once.....and, I thought it was just me that did that ;-)
tempest is offline
post #14 of 16 Old 05-08-2012
travlin-easy's Avatar
In my case, I found that I had to double reef the main, and in fairly heavy winds I used just a tab of jib to achieve the necessary angle. My Morgan 33 O.I. is a full keeled boat, which tends to heave-to easier than a fin keeled boat. However, the book explains all this. Another option is to do a rental download of the book from YouTube at Storm Tactics Video Preview - YouTube
I haven't tried using an 8-foot parachute yet off a yoke yet, but that's not out of the realm of possibility sometime in the near future. Check out the video link and you'll find some neat things to watch.
Here the Amazon link to the paperback version of the book, where you can also take a glimpse of the book's contents. http://www.amazon.com/Storm-Tactics-Handbook-Heaving--Conditions/dp/1929214472/ref=sr_1_1?ie=UTF8&qid=1336519802&sr=8-1#reader_1929214472
Good luck,
Gary
travlin-easy is offline
post #15 of 16 Old 05-08-2012
Senior Cruiser
sea_hunter's Avatar
You can't heave to in that little of wind and expect any kind of balance. Try again at 30 knots.
sea_hunter is offline
post #16 of 16 Old 05-09-2012
This explains it well: How to Heave To - Heave-to a Sailboat
casey1999 and travlineasy like this.
Tom S.
O-Day 22
SchwarckT is offline
Heaving to MITBeta Seamanship & Navigation 33 07-28-2011 11:01 PM
Heaving to.....what gives. deadchest General Discussion (sailing related) 21 05-14-2011 07:43 PM
Heaving to StarJourney Learning to Sail 10 06-06-2010 02:27 PM
Heaving a cat rig? drobarge Seamanship & Navigation 4 03-17-2010 07:44 PM
What Is Heaving-to? John Rousmaniere Seamanship Articles 0 10-05-1999 09:00 PM
