"Hang" storage for a fin keel sailboat? - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 10 Old 05-08-2012 Thread Starter
I'm looking at a 25' sailboat with a fin keel, which is stored on what looks like a powerboat rack. It displaces 3800 lb.
There's no support under the keel and with 1800 lb of ballast, I would think that weight is putting stress on the hull.
I realize when a boat is floating there's no support for the keel either, but pressure on the hull is more evenly distributed.
The boat has been hanging there for a couple of years. Do you think there's a potential for hull damage?
A survey is not an option because the boat is a low priced fixer-upper.
whitewater7 is offline
post #2 of 10 Old 05-08-2012
One of None
deniseO30's Avatar
Re: "Hang" storage for a fin keel sailboat?
"Buyer Bware" then! But it's probably ok. not like a larger boat with way way more ballast.
My last project!
deniseO30 is offline
post #3 of 10 Old 05-08-2012
Since it's just 'hanging there', you should be able to see any evidence of deformation or dimpling along the rack it's sitting on.
Not a real heavy boat so it could be OK.. presumably the rig is down too?
wdwright1967 likes this.
Faster is online now
post #4 of 10 Old 05-08-2012 Thread Starter
The mast is still up.
It's looks like a nice dry boat on the inside, well right now, anyway.
post #5 of 10 Old 05-08-2012
catamount's Avatar
As suggested above, if there were any hull damage, you ought to be able to see with your own eye any deformation or un-fairness to the hull that would be a consequence of hanging on those racks. If the hull looks fair, then it probably is fair!
A survey is always an option, it's just that you don't think it is worthwhile in this case.
I had a survey done when I bought a low priced fixer-upper, because I thought it worthwhile in that case.
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
post #6 of 10 Old 05-08-2012 Thread Starter
I will take a closer look at the area along the boards that it is resting on to see if the fiberglass looks stressed.
Thanks for your comments.
post #7 of 10 Old 05-09-2012
Working for next Boat
MobiusALilBitTwisted's Avatar
Give this a quick read,How To Do your Own Marine Survey by a Marine Surveyor and then go look her over,
S/V
1985 Venture 25
Fl Gulf Coast
GrahamO
"Möbius,You need another drink. You are starting to make sense".
MobiusALilBitTwisted is offline
post #8 of 10 Old 05-09-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
My 0.02:
Bolt on Keel: Look for separation at the keel/hull join; a crack is maybe ok, actual separation would be really bad. Look especially for a change in this area when she goes back on her keel.
Encapsulated Keel: The keel is not an issue, look for depressions in the FG at the rack supports; they will likely pop back out.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #9 of 10 Old 05-09-2012
catamount's Avatar
In terms of self-surveying, Don Casey's book "Inspecting the Aging Fiberglass Sailboat" is a pretty good guide. Do you know if the hull of the boat you are looking at is solid fiberglass, or a cored construction?
post #10 of 10 Old 05-10-2012 Thread Starter
I'm not sure if the fiberglass is cored.
It's a 1980's Tanzer. I like Canadian built/designed boats.
There seems to be mixed opinions about whether there's a potential for damage.
I can't easily visit the boat to take a better look to see if there is damage, and waiting to see if the fiberglass changes once it's properly blocked doesn't sound like a good idea.
There's a reason why sailboats are stored on their keels.
I think I will pass on this one.
Thanks for the comments and links.
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Cal 25 engine storage "bulkhead" - structural? Whippersnapper Cal 0 03-31-2010 11:33 AM
Centerboard and "full keel" on the same sailboat - why? Northbeach Sailboat Design and Construction 9 04-06-2009 10:23 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
