Now what do I do? - SailNet Community
 1Likes
  • 1 Post By msmith10
post #1 of 7 Old 05-08-2012 Thread Starter
flyingwelshman's Avatar
Now what do I do?
I wanted to remove the vinyl lettering on my boat. I googled 'vinyl lettering removal from boat' and found an old thread on Sailnet.
Someone recommended a device called a 3M Stripe Off Wheel. Coincidentally someone at my marina recommended the same device. I googled, I watched YouTube - it seemed like the bee's knees.
Today I used a hair drier to warm up the vinyl and peeled off as much as I could. Next I took the 3M Stripe Off Wheel and followed the directions. The residual vinyl came off a treat but left some clumps and what appeared to be adhesive.
I took some acetone and removed the residue - everything came off.
Unfortunately there now looks like some staining where the old name was. It appears to be some discolouration of the fibreglass caused by the stripe off disk.
If this is 'scorching' caused by the friction of the rubber disk how can I get rid of it?
I thought I would try some coarse rubbing compound, or maybe some fine-grit sandpaper (or wet & dry emery).
Does anyone else have any ideas?
Thanks
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #2 of 7 Old 05-08-2012
Re: Now what do I do?
A colour difference and 'shadowing' of the old name under a decal is common.. the gel coat was protected by the decal and has aged differently.
However if there's discolouration you can link to the use of the wheel then it probably got a little hot... Starting with compound, and/or fine (600+) wet sand may be a starting point, followed by an overall polish afterwards.
The other consideration might be how much of the old your new name/decal etc will cover..
Faster is online now
post #3 of 7 Old 05-08-2012
Junior member, rest old
msmith10's Avatar
I had the same thing happen with discoloration under old lettering. After a couple of seasons of compounding and waxing, it was gone.
travlineasy likes this.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #4 of 7 Old 05-08-2012 Thread Starter
Thanks for the suggestions.
I am pretty sure that the discolouration was caused by the wheel as it does not correspond to where the original lettering was.
1989 Hunter 30'
post #5 of 7 Old 05-08-2012
travlin-easy's Avatar
Try compounding the area, then apply some wax and buff it out. If this doesn't solve the problem, clean the wax off with a good detergent and let the sun and weather take care of the problem. It will probably take a season or two, but eventually the entire stern will be the same color.
Good Luck,
Gary
travlin-easy is offline
post #6 of 7 Old 05-08-2012
Best Looking MALE Mod
Cruisingdad's Avatar
Thanks
Go back on with the same name. You won't tell you ever messed up and will look like a hero on Sailnet.
I am a genius...
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #7 of 7 Old 05-08-2012
COmopound. Use Maguires or the 3m product. It will help. I never saw it totally remove it. Sorry.
You can also paint. Extreme suggestion.
I never tried wet sanding.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
