Like Tree8Likes
  #21
Old 05-09-2012
Kenn43 is on a distinguished road
Re: Closing seacocks
Yes. Those that I can. I have 5 thru-hulls and close all except the 2 cockpit scupper seacocks.
  #22
Old 05-09-2012
sebez is on a distinguished road
I usually only get down to the boat ever couple of weeks and when I leave all the seacocks get closed. Peace of mind and it exercises the valves. I do like the idea of hanging the engine key on the engine intake seacock
  #23
Old 05-09-2012
Irrationally Exuberant
arf145 is on a distinguished road
We always close the seacocks when we leave the boat. We have 4: engine water, galley sink, head sink, and toilet flush water. The toilet one is always closed now, a good thing, because it would be a slight pain to do every time.
I would turn around and go back to the boat if it occurred to me that I'd forgotten--I've seen a sunken sailboat in a slip--sad and scary.
Tom K
2000 Beneteau 331
1987 Pearson 28-2
Northern Chesapeake Bay
  #24
Old 05-09-2012
I also like the idea of hanging the engine key on the engine intake seacock. Plan on giving it a try.
  #25
Old 05-09-2012
Cruisingdad's Avatar
Best Looking MALE Mod
Yes if leaving the boat for a period of time (in days). No when Living aboard/cruising. Only exception is when anchored for a period of time, we close main and sometimes generator.
I am a big proponent of exercising your seacocks. I am also of the mind that they should stay closed if you are leaving the boat for the weekend or week or something similar. But that is just me.
Brian
Lets see: 8 sea cocks. Only 8 because I intentionally plumbed to minimize holes in the boat/sea cocks.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Follow me on Facebook:
  #26
Old 05-09-2012
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious will become famous soon enough
Originally Posted by SVAuspicious View Post
Nope.
Below the waterline:
1. Washdown intake
2. Port galley sink drain
3. Starboard galley sink drain
4. Starboard deck drains
5. Port deck drains
6. Starboard cockpit drain (with seat drain)
7. Port cockpit drain
8. Main engine cooling inlet
9. Generator cooling inlet
10. Generator cooling outlet
11. Head sink drain
12. Head inlet
13. Head outlet
14. A/C cooling inlet
Above the waterline:
15. Forward A/C outlet
16. Aft A/C outlet
17. Main bilge
18. High bilge
19. Manual bilge
20. Shower sump
21. Generator dry exhaust
22. Main engine wet exhaust
23. Diesel heater exhaust
I'm on the boat most of the day almost every day. I carefully inspect the hoses and cycle the valves quarterly. That's working for me.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
  #27
Old 05-09-2012
Da Most Educated Red Neck
rockDAWG is on a distinguished road
Originally Posted by Minnewaska View Post
We have 20 thru hulls, with seacocks, that I can count off the top of my head.
Closing seacocks
May be you can get a SPOT II (if you don't have one yet) and hot wired to a flood sensor to send you a text message when you boat is about to sink. Damn closing 20 seacocks is lot of work. I am just sayin'
  #28
Old 05-09-2012
I actually really like the Sea Chest idea that is commong on many Tayanas. Basically, it is one larger hole in the boat a the very bottom with a very large strainer that feeds everthing. Sure does make a leak quick to stop. I am sure there is some nautical reason why Catalina or Bene or most other manufacturers do not use a Sea Chest (probably cost) bu is still seems like the way to go to me.
If I had 20 sea cocks, I can guarantee you I would be looking for a way to start reducing them. For example, I have a washdown pump. I could have put in a whole new Thull for it. Instead, I pulled off the shower drain. No biggie. I pulled for a watermaker off of my Air Conditioner. I figure I will not run them both at the same time anyways and the AC is furthest forward in the boat. The Gen and engine have their own Thull, which Ii agree with, but Catalina put those in anyways.
Anyways, random thoughts.
Brian
Com-Pac 16
  #29
Old 05-09-2012
smackdaddy's Avatar
Last Man Standing
Nevertheless, let's sound off. Do you close your thru hulls when you leave your boat?
Dude, 20? That's not a boat that's a floating one of these:
I always close my 2 seacocks. The dudes around here have scared the hell out of me.
  #30
Old 05-09-2012
T37Chef's Avatar
Wood Cutting Board User
T37Chef will become famous soon enough
I actually really like the Sea Chest idea that is commong on many Tayanas. Anyways, random thoughts.
Brian
I believe Caliber has been using this idea for a while now?
Shawn
Tartan 37 - S/V Windgeist
Sailing the Chesapeake Bay
Photo by Joe McCary
You may post attachments
You may edit your posts
Closing on a new boat BCC1 Boat Buyers & Sellers Forum 4 03-24-2012 04:14 AM
Closing Costs? trisstan87 General Discussion (sailing related) 9 11-06-2010 08:22 PM
Boat companies closing Omatako General Discussion (sailing related) 12 02-19-2009 12:49 PM
Closing Seacocks Tom Wood Gear and Maintenance Articles 0 12-20-2000 07:00 PM
SEO by vBSEO 3.6.1
