Closing seacocks - Page 4 - SailNet Community
 8Likes
post #31 of 83 Old 05-09-2012
Barquito
Barquito's Avatar
Re: Closing seacocks
I close my 3 seacocks every time I leave the boat (usually for a week). There are still a number of thru-hulls w/o seacocks: rudder stuffing box, shaft stuffing box, two cockpit scuppers, knotmeter wheel. I would imagine a good drip would sink most boats in a week.
Valiant 32
Barquito is offline
post #32 of 83 Old 05-09-2012
bristol299bob's Avatar
I close all seacocks, except the 2 cockpit drains, when I leave the boat unattended. To avoid the possibility of starting the engine without raw water open, I leave the key looped on the raw water seacock.
bristol299bob is offline
post #33 of 83 Old 05-09-2012
casey1999's Avatar
I close all except the two cockpit drain valves (need to stay open to drain rain water).
I also have this remote monitor which will call my cell phone for high bilge water or low battery voltage. The company has been bought by Mcdermott Light and Signal. Gives me peace of mind if away from boat. Figure if I get high water alarm I can get to boat and solve problem before she sinks.
Boatsense Solutions
The unit is now monitored by:
Marine Navigation Lights by McDermott
Contact Mcdermott Light if you are interested in purchasing.
This unit has multiple normal open or normal closed contacts- you can wire these as an intruder alarm, smoke alarm, low temp, high temp or whatever you like. The unit will text message of the abnormal condition.
casey1999 is offline
post #34 of 83 Old 05-09-2012
captainrizzo's Avatar
I don't close mine during the sailing season.
-Riz
2005 Catalina 350 Grazia
"If you want to build a ship, don't herd people together to collect wood. Just teach them to long for the endless immensity of the sea"
Antoine de Saint
My Blog:
captainrizzo is offline
post #35 of 83 Old 05-09-2012
priscilla's Avatar
No
Priscilla
priscilla is offline
post #36 of 83 Old 05-09-2012
Originally Posted by SVAuspicious View Post
Below the waterline:
1. Washdown intake - Tee'd to another intake
2. Port galley sink drain - Above the waterline
3. Starboard galley sink drain- Above the waterline
4. Starboard deck drains- Above the waterline
5. Port deck drains- Above the waterline
6. Starboard cockpit drain (with seat drain)- Above the waterline
7. Port cockpit drain- Above the waterline
8. Main engine cooling inlet - Closed every time I leave boat
9. Generator cooling inletClosed every time I leave boat
10. Generator cooling outletAbove the waterline
11. Head sink drainAbove the waterline
12. Head inlet - Freshwater
13. Head outletClosed when less than 3 miles out
14. A/C cooling inlet Closed every time I leave boat
Above the waterline:
OK to leave open.
15. Forward A/C outlet
16. Aft A/C outlet
17. Main bilge
18. High bilge
19. Manual bilge
20. Shower sump
21. Generator dry exhaust
22. Main engine wet exhaust
23. Diesel heater exhaust
I'm on the boat most of the day almost every day. I carefully inspect the hoses and cycle the valves quarterly. That's working for me.
If it don't need to be below waterline eliminate it, if it does, then locate near a hatch so you can close it.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #37 of 83 Old 05-09-2012
Senior Moment Member
SloopJonB's Avatar
A friends Hunter has the best seacock setup I've seen. The head, galley and engine are all clustered around the companionway so under the galley sole is a pit with all the seacocks, strainer etc. clustered in one place, labelled, plugs wired to each and everything right at hand - very slick.
SloopJonB is offline
post #38 of 83 Old 05-09-2012
travlin-easy's Avatar
I close all 6 every time I leave the boat--even if it's for just a couple hours.
Gary
travlin-easy is offline
post #39 of 83 Old 05-09-2012
Courtney the Dancer
jrd22's Avatar
I close them all except the cockpit drains, bilge pumps and the exhaust valve (above waterline). Like others have said we leave the ignition key on the raw water inlet valve.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #40 of 83 Old 05-09-2012
Armchair Horn Sailor
Alden68's Avatar
I closed all 7 every time I left the boat if I wanted peace of mind ashore. I replaced the cockpit drain thru-hulls, seacocks and hoses when I bought the boat knowing that they would always remain open. I usually closed the engine, head intake & discharge if not being used when ON the boat. Why not? The alternative could really suck.
Alden68 is offline
Closing Costs? trisstan87 General Discussion (sailing related) 9 11-06-2010 08:22 PM
Boat companies closing Omatako General Discussion (sailing related) 12 02-19-2009 12:49 PM
Closing Seacocks Tom Wood Gear and Maintenance Articles 0 12-20-2000 07:00 PM
