Closing seacocks - Page 7 - SailNet Community
 8Likes
post #61 of 83 Old 05-10-2012
Re: Closing seacocks
We have 8 below the waterline in our 35' Bene & always close all of them when leaving the boat for a day or more. Two cockpit drains exit the transom about 12" above waterline, so no need to bother with them - no provision to close them anyway.
davmarwood is offline
post #62 of 83 Old 05-10-2012 Thread Starter
Here's another example of my thru hull OCD. Last Fall, I split a hose below the waterline, when trying to remove it from the barb to winterize. I didn't have the right diameter to replace it, so I left the seacock closed and removed the hose to the next connection. Just having the seacock closed, with no hose attached, made me nervous, so I banged a dowel into the barb.
Would you?
Jeanneau 54DS
Minnewaska is offline
post #63 of 83 Old 05-10-2012
svHornblower's Avatar
I also close all mine when I leave the boat. Not sure I would as far as banging a dowel into the barb of a closed seacock but that is buy no means a dumb idea. Better safe than sorry.
1985 C&C 37
Neptune Beach FL
svHornblower is offline
post #64 of 83 Old 05-10-2012
Best Looking MALE Mod
Cruisingdad's Avatar
Would you?
Uh, nope. Sorry. There comes a point when its just up to the good Lord. You probably gotta a better chance of sinking via lightning that that Thull opening on its own and sinking the boat. But hey... if it makes you sleep better it's worth it.
B
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #65 of 83 Old 05-10-2012
catamount's Avatar
Would you?
Yeah, I probably would. Belt and suspenders! Of course it would depend on how long it would be before I was able to replace the hose. Later that same day, probably not. A week or two -- yes!
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
post #66 of 83 Old 05-10-2012
jimmalkin's Avatar
Minne - I had 18 on Taronga - marked all locations with blue tape when offshore or overnight passage for ease of location (should need be.) I always close engine intake, head intakes and overboard thru-hulls when leaving the boat - the rest stay open. Also - re: barbs - I have always capped either with pipe ends or bungs any thru-hulls no longer in use. It's just an easy extra layer of caution.
White Rabbit
Vineyard Haven
jimmalkin is offline
post #67 of 83 Old 05-10-2012
Would you?
Hey Minne-,
You know what you need? I cannot remember who makes it, but there is this electronic device that automatically opens and closes your Thulls for you. Also warns you of the bilge going off. Think I saw it in Cruising World a while back.
I mean, come on! Boating isn't cheap!!
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #68 of 83 Old 05-10-2012 Thread Starter
Bilge alarms are good. If you find the link, send it along. Auto seacocks sound cool. Maybe I'll have them on my dream boat one day......
I have an audible high water alarm already. It sounds down below as well as in the cockpit. I had an alarm that sounded if the pump simply ran for more than about 5 seconds straight. However, it must have shorted because it would go off randomly.
In fact, it went off as I was sneaking through the inlet into the Great Salt Pond on Block Island. I had some big monster stinkpot behind me and opposing traffic to port. The inlet is tight enough that you could pass cocktails to opposing traffic, so this was a really bad time to think there was a flood in the bilge. False alarm, but the salon got tossed pretty fast to learn that.
Jeanneau 54DS
post #69 of 83 Old 05-10-2012
20 seacocks seems extreme. I have one for the sink drain, which I rarely close, and one for the watermaker, which is closed most of the time. I have two seacocks, total.
I suggest you try think of ways to eliminate most of those seacocks.
Standpipes can reduce the need to close some.
chrisncate likes this.
Brent Swain is offline
post #70 of 83 Old 05-10-2012
MikeinLA's Avatar
My feelings exactly. I've owned this boat for 13 years and other than the engine intake, I don't close any of them ever. I do have them lubed and serviced at haulout time, though. My seacocks are not well located and if I had to bend and reach and remove cushions, etc every time I left the boat, I would seriously just sell the boat. Of course, my refer has also never been turned off in the past 13 years. This stuff is why God made insurance and checkbooks.
Mike
MikeinLA is offline
Closing Costs? trisstan87 General Discussion (sailing related) 9 11-06-2010 08:22 PM
Boat companies closing Omatako General Discussion (sailing related) 12 02-19-2009 12:49 PM
Closing Seacocks Tom Wood Gear and Maintenance Articles 0 12-20-2000 07:00 PM
