Remove old painted name from hull - Page 2 - SailNet Community
 2Likes
post #11 of 15 Old 05-09-2012 Thread Starter
BreakAwayFL's Avatar
Re: Remove old painted name from hull
Thanks, definitely getting psyched up!
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
BreakAwayFL is offline
post #12 of 15 Old 05-09-2012
nodders's Avatar
I successfully used oven cleaner on my boat to remove the name on both sides of the bow. It took 2 goes (maybe because it was cold?) but worked beautifully! Now to get the name off the transom and rename her. Hopefully Neptune approves!
I am not really from Toronto
nodders is offline
post #13 of 15 Old 05-12-2012
vtsailguy's Avatar
Originally Posted by Silvio View Post
If it is painted on top of gellcoat easy off oven cleaner is a real quick and simple way to remove painted names etc.
I used oven cleaner and it was most successful.
However, it just removed the pigment. There is a colorless raised bump where all the letters were. Its relatively obvious.
Three mini-pirates scour the Caribbean Seas with stops for ice cream and legos
Latest blog post:
vtsailguy is offline
post #14 of 15 Old 05-13-2012
When I first got my boat, I compounded the gelcoat using an orbital buffer to bring back the color. When I got to the transom, I compounded as usual and didn't even think twice about the painted on name. Somewhat to my dismay, I discovered that I was accidentally compounding the painted on name right off.
I don't know if it works when you're doing it on purpose or not!
Silvio likes this.
Quickstep192 is offline
post #15 of 15 Old 05-14-2012 Thread Starter
Oven cleaner worked great! Two coats over a one hour period removed all but the outline. I'm going to try again next weekend before I give up on it. If that doesn't work I'll try the compound method next, as it's the least destructive.
Silvio likes this.
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
cleaning a hull painted with perception. superiorvoyager Gear & Maintenance 2 04-13-2012 10:22 PM
Removal of Painted name from Awlgrip Hull Rustyf General Discussion (sailing related) 5 01-06-2012 11:38 PM
Has anyone painted their hull in the water? L124C Gear & Maintenance 26 12-26-2011 12:28 PM
Remove painted name from hull docsabre Gear & Maintenance 5 05-05-2002 08:44 AM
Remove painted name from hull docsabre Gear & Maintenance 0 04-24-2002 05:37 AM
