Like Tree2Likes
  #1
Old 05-09-2012
BreakAwayFL's Avatar
BreakAwayFL is on a distinguished road
Remove old painted name from hull
Hello all,
I'm ready to remove the old name from the boat. Unfortunately (for me), it was painted on, and I'm trying to make sure I am removing it in the best way.
What I had decided on was this:
  • Wash/Scrub the stern with a heavy duty cleaner that should strip any wax remaining
  • Slowly and gently sand with 1000 grit paper with a random orbital sander until most of the lettering is gone
  • Do the same with 1600 grit until the remainder is removed
  • same grit to rest of stern
  • Polish
  • Apply Vinyl lettering
  • Wax
  • Next week, wax again
Does this sound right, or am I out of whack here?
Also, is the 1000 grit too coarse and the 1600 grit fine enough?
Thanks for any input!
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
  #2
Old 05-09-2012
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
Re: Remove old painted name from hull
If it is painted on top of gellcoat easy off oven cleaner is a real quick and simple way to remove painted names etc. Spray the easy off cleaner on, let it sit for 10 -15 minutes, wipe off with paper towels. Repeat if anything remains, rinse. Done. No sanding needed. Sometimes easy off will leave a yellow haze behind that can neutralized with vinegar or you can wait a day or two and it will go away on its own.
SV S.S.R.I
It's my happy pill
  #3
Old 05-09-2012
Really?
Really really?
I'll be trying this Saturday. If this works, I'll have a bottle of rum in your hands post haste!
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
  #4
Old 05-09-2012
PalmettoSailor will become famous soon enough
Originally Posted by BreakAwayFL View Post
Really?
Really really?
Yeah not so really in my experience. Our first boat had a painted on name and we tried EZ-Off along with several forms of paint remover. We eventually got it OFF, but it was anything but EZ.
The key to avoid tennis (paint removal) elbow is to let the chemical do its job and not get in too big a hurry. Apply, wait, wipe and repeat. Be generous with whatever you choose.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
  #5
Old 05-09-2012
RichH's Avatar
RichH will become famous soon enough
Spray on Easy Off, cover with saran wrap, let sit/soak ... then wipe off. May need to repeat, etc .
  #6
Old 05-09-2012
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I sanded my transom rather aggresively (going to paint anyway), and still had shadow of name. Might depend a lot on the materials and techniques used to apply the painted name.
Bristol 27
Cirque
  #7
Old 05-09-2012
rmeador is on a distinguished road
I took the painted name off mine with some orange-based paint remover I bought at Home Depot. I believe it was intended to remove graffiti. It took several applications, and waiting about 15 mins after each application, but the paint came off with a scraper after that. I then compounded and polished the entire transom. There is a slight ghost of the old name just because the gelcoat under there wasn't weathered as much, but it's really unnoticable unless you know to look for it.
1979 Gulfstar 37 Laissez Faire
  #8
Old 05-09-2012
I thought about paint remover (makes sense right?) but was concerned about taking off the gel along with it. (might be a dumb newbie statement, but there you go)
Unless anyone has better ideas, I am going to try the Easy-Off method first, since it seems less aggressive. After that I'll try the orange based remover. I don't have a ton of faith in it since the name on my boat is 40 years old, but I'll give it a shot!
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
  #9
Old 05-09-2012
I was also afraid of taking the gel coat off, and I think when I left the paint remover on there for a really long time, it might have softened the gel coat a little, but it's now been a year and shows no adverse effects. I'd just try to work quickly once it's soaked for a while, and wash it off really well.
  #10
Old 05-09-2012
Silvio's Avatar
Worked well for me. Name had been painted on for 8 years and was in good shape. I did it as I laid out above on a miserably hot summer day in Florida. Let the Easy off work and don't get in too much of a hurry. On mine it initially left a yellowish shadow, but that was gone with no intervention in a couple of days. Others have told me that vinegar will remove the yellow immediately.
I also use Easy off to remove old decals from the gellcoat, off in seconds with no residue and no need for heat.
good luck!
SV S.S.R.I
It's my happy pill
You may post attachments
You may edit your posts
cleaning a hull painted with perception. superiorvoyager Gear & Maintenance 2 04-13-2012 10:22 PM
Removal of Painted name from Awlgrip Hull Rustyf General Discussion (sailing related) 5 01-06-2012 11:38 PM
Has anyone painted their hull in the water? L124C Gear & Maintenance 26 12-26-2011 12:28 PM
Remove painted name from hull docsabre Gear & Maintenance 5 05-05-2002 08:44 AM
Remove painted name from hull docsabre Gear & Maintenance 0 04-24-2002 05:37 AM
SEO by vBSEO 3.6.1
