Early Cutlass bearing wear. Is this a problem? - Page 2 - SailNet Community
 1Likes
post #11 of 23 Old 05-10-2012
Otter
DivingOtter's Avatar
Re: Early Cutlass bearing wear. Is this a problem?
Originally Posted by casey1999 View Post
I do get a "thumping" vibration at low rpm (try to avoid that), seems to be coming from around the cutlass bearing strut. Prop is relatively clean as I dive it regularly.
Make sure there is no Dogears on the flukes
DivingOtter is offline
post #12 of 23 Old 05-10-2012
casey1999's Avatar
Originally Posted by DivingOtter View Post
I have seen that happen with an unbalanced or damaged wheel. People ignoring it till it develops into a larger problem. I tell my customers an unbalanced wheel is like an unbalanced tire. Maybe just a little vibration but over time it will slowly wear out other components.
Agree. It is on top of my list. Don't motor much, but will rework asap.
casey1999 is offline
post #13 of 23 Old 05-10-2012 Thread Starter
GrahamO's Avatar
How do you balance a prop? Just make sure it is clean?
Pity you cannot take it to the local tyre shop....
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #14 of 23 Old 05-10-2012
Learning the HARD way...
eherlihy's Avatar
A local propeller shop would be able to clean and balance your prop. It should cost ~$100, if you can get it off the shaft. Many prop shops do not work ON boats.
New England Propeller is located in Plymouth, MA, and Roses in Glocester, MA are two recommended ones.
eherlihy is online now
post #15 of 23 Old 05-13-2012 Thread Starter
GrahamO's Avatar
Thanks for the info.
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #16 of 23 Old 05-14-2012
Otter
Thats why i have deal with a local prop company. I pull the wheel in water, deliver it to the shop, pick up and replace in water. Its all about making people happy.
post #17 of 23 Old 05-14-2012
snake charmer, cat herder
zeehag's Avatar
check motor mounts. a problem is usually reflected elsewhere in the line of items to be addressed. alignment is important. 65 hours can be good IFF the engine was on good mounts. if not, can be what you found.
formosa 41, cruising tropics
zeehag is offline
post #18 of 23 Old 07-11-2012
As a bearing supplier it can often be bearing carrier alignment that is not noticed, look carefully at the clearance at either end of the P bracket if the boat has one.
It is also not engine hours that wear a bearing as when it is running the shaft is on a film of water so there is no wear. The bearing material (or shaft) wear at start up and run down and the wear can be accelerated by the type of sand or silt in the water column. So a boat that does many short runs (as yachts often do in the Solent) will see higher wear than a motor boat. Most yachts will start and stop the engine twice for every journey as they motor out of or into a marina/anchorage a mobo only does this once so will see half the wear.
Acceptable bearing cearances will differ for different bearing materials/suppliers.
HDChopper likes this.
Kutter is offline
post #19 of 23 Old 07-11-2012
I use a piece of shaft the same diameter as my main shaft with the taper cut on it, and two drill holes ,one on either end. I put the prop on this taper. A jig which holds the prop, on this shaft thru two sharpeened bolts in these pin holes lets me see which is the heavier blade. If I grind the heavier one down, to the point where, when I spin the prop, it stops at a different point every time, the prop is balanced. Leaving this shaft a bit long, lets you hold a patten on the blade and line it up with the shaft for pitching it.
Brent Swain is offline
post #20 of 23 Old 07-12-2012
Over Hill Sailing Club
smurphny's Avatar
If your prop is dog-eared, you can often fix it in-place yourself with a couple of opposed small sledge hammers. Getting the prop off some boats is a major operation. Sailboats usually have very short(4' or so) shafts, so whip or a bent shaft is seldom the problem. You're also not dealing with a strut (or are you?) that's out of whack. I would agree with those above that the prop is likely the problem. Even a small misalignment at the coupling would not cause premature bearing wear like that.
Also check the water passages that allow water flow into the bearing. A dry bearing fails quickly.
smurphny is offline
Cutlass Bearing and rudder bearing smillinjack Gear & Maintenance 3 07-11-2010 08:18 PM
PS 37 Cutlass Bearing waypt1 Pacific Seacraft 5 01-15-2008 03:03 PM
Cutlass bearing alpeaks Gear & Maintenance 2 05-17-2004 01:10 AM
Cutlass bearing bstrebe Gear & Maintenance 2 10-04-2003 03:45 PM
Cutlass bearing lgsailor52 Gear & Maintenance 5 07-04-2002 06:25 AM
