-   -   Tank Drain (http://www.sailnet.com/forums/general-discussion-sailing-related/87262-tank-drain.html)
twenty1knots 05-10-2012 10:22 PM
Tank Drain
Im trying to get out the last few drops out of a 20 gal fuel tank. I am thinking to insert a long piece of foam through the tank opening and scrape it around the bottom. Take out, squeeze fuel and repeat.
Any other suggestions/ideas?
sea_hunter 05-11-2012 07:19 AM
Stuff a bilge pad inside to soak up last bits.
Barquito 05-11-2012 01:17 PM
Re: Tank Drain
Lighted match...:laugher
Barquito 05-11-2012 01:18 PM
Re: Tank Drain
Might not be any safer than a lighted match, but, how about a shop-vac with a long tube attached?
Waltthesalt 05-12-2012 12:45 AM
Re: Tank Drain
You can get a DC fuel pump cheaply but it won't be up to getting drops out. If this is diesel that's ok. If you're talking about welding on a gas tank tie will be flushing out the tank a couple of times, ventillating the tank and then it will be iffy if the welder thinks its' safe. You may have to tru the the match
