Refinishing Tiller - SailNet Community
post #1 of 3 Old 05-15-2012 Thread Starter
g0twind's Avatar
Refinishing Tiller
Is this clean enough for Cetol?
1974 Paceship PY23 "Barely Awake"
Hull # 001
g0twind is offline
post #2 of 3 Old 05-15-2012
rbrasi's Avatar
Re: Refinishing Tiller
Hard to tell. If it's completely stripped, then yes. I recommend prepping with interlux 216 and thinning your first coat with it.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #3 of 3 Old 05-15-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
I'd use some 'brightener' to remove the dark stains before sealing it up. Some products allow you to use bleach & water; others specify a certain brightener. Check the can for the finish you are using. I've never used Cetol, but everything I have used made the surface darker; if the stains are dark now...
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
Refinishing Teak jetdrvr393 Gear & Maintenance 32 11-01-2011 01:07 PM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 05:53 PM
Hull refinishing loomaz Gear & Maintenance 7 11-28-2006 01:17 PM
refinishing a tiller jhasailing Gear & Maintenance 1 05-15-2003 02:15 PM
Refinishing Teak Dan Dickison Gear and Maintenance Articles 0 05-22-2001 09:00 PM
