Going up the mast when the boat is in a lift - Page 2 - SailNet Community
 4Likes
post #11 of 18 Old 05-23-2012
Re: Going up the mast when the boat is in a lift
Same answer.
Jeanneau 54DS
Minnewaska is offline
post #12 of 18 Old 05-23-2012
rugosa's Avatar
arf 145 is right. If the yard will allow it, consider another yard, it's a huge liability to them - whether a Travellift, crane, forklift. Going aloft on a 24' boat you'll experience plenty of motion. I'd pull the mast or get a lift up on the crane while boat is in water or ashore.
rugosa is offline
post #13 of 18 Old 05-23-2012
Broad Reachin'
kwaltersmi's Avatar
If she's a 24 footer, it might very well be easier to just drop the stick.
Minnewaska likes this.
Catalina 34
kwaltersmi is offline
post #14 of 18 Old 05-23-2012
why not! if the boat is slung properly, boatyard employees do it all the time but i doubt the yard would allow you to do it
sawingknots is offline
post #15 of 18 Old 05-23-2012
Seņor Member
ottos's Avatar
re: going aloft on the hard
There's a lot of experienced people on this forum who are pretty emphatic about not going up when the boat is on stands. Do a search on that....
Thinking about it - in the water you've got the keel working for you as a righting moment. On stands, not so much.
I would have thought in the slings wouldn't be so bad, but then have you ever seen the video's of boats falling out of slings?
ottos is offline
post #16 of 18 Old 05-23-2012
Glad I found Sailnet
Bene505's Avatar
Why risk it on such a small boat? You are a significant percentage of the keel weight on a 24 foot boat. And you are a couple dozen feet in the air, versus the few feet of moment arm the keel has.
Regards,
Brad
Bene505 is offline
post #17 of 18 Old 05-23-2012
I worked on a 70' race boats management plan... We would never have considered sending someone up the rig on the hard. Not a chance. Boats fall off stands all the time even when everything is done right, but adding a few thousand pounds of torque to the top of the mast while it is blocked of...l no way.
Let's say you are 150lbs, and climb to the top of a 30' rig. That weight aloft can generate up to 4500foot pounds of torque. While the boat is in the water that force can be absorbed by the boat healing over, and allowing the keel to take some of the heeling force.
On the hard the boat can't heel over, which means you are relying completely on the stands to not only hold the weight of the boat, but any heeling force as well. They just aren't designed to do this. If fact I have never seen a yard that supports a boat to prevent it from rolling in the stands. Though if a boat happened to be top heavy enough I guess they might.
Stumble is offline
post #18 of 18 Old 05-25-2012
Wish I never found SN!
SimonV's Avatar
Things that make you go "Mmmmmmmmmmm"
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
Boat lift: Okay For A Sailboat? Charrob General Discussion (sailing related) 10 09-10-2010 12:16 PM
Making a boat lift DePlano General Discussion (sailing related) 13 05-15-2008 07:27 PM
boat lift? dman Gear & Maintenance 0 04-11-2008 07:03 AM
Boat lift in a storm knothead General Discussion (sailing related) 5 08-27-2006 10:24 PM
anyone using a boat lift? DuaneIsing Gear & Maintenance 0 01-03-2003 08:25 AM
