Like Tree4Likes
  #1
Old 05-22-2012
Quickstep192 is on a distinguished road
Going up the mast when the boat is in a lift
So, is it safer to go up the mast when the boat is in a lift than it is when the boat is in the water?
In the lift, the boat isn't subject to wakes or listing. But, could that weigh aloft cause the boat to tip or catastrophically shift?
  #2
Old 05-22-2012
KIVALO's Avatar
KIVALO is on a distinguished road
Re: Going up the mast when the boat is in a lift
how big/heavy of a boat are you talking about?
Brad
s/v KIVALO
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
  #3
Old 05-22-2012
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
If you're talking about in the slings of a travel lift or on the hard in any manner, I personally wouldn't be going aloft. Waves and wakes can be accounted for with safety gear and proper technique, but having the boat fall from a lift (or jack stands, or a cradle) would be catastrophic.
  #4
Old 05-22-2012
Irrationally Exuberant
arf145 is on a distinguished road
Gosh, would anyone operating a lift even let you go up the mast? I wouldn't.
It feels a little iffy up there when you are in the water and the boat rocks, but it's not going anywhere. Try going up at a quiet time.
Tom K
2000 Beneteau 331
1987 Pearson 28-2
Northern Chesapeake Bay
  #5
Old 05-22-2012
ScuzzMonkey is on a distinguished road
I don't think I would go up while it's in the slings, but I have gone up the mast while on the hard, and it's much more productive than going up while in the water. Everything is rock solid; much easier to get work done.
If the boat is blocked up the way I would want it to be anyway, I don't think there's any danger of tipping it. Although you're introducing weight aloft, I can't see how you would generate any lateral force of any significance... you're suspended from the mast, the weight will all bear straight down. Even if you were swinging around like a monkey (which I wouldn't), I doubt you would generate a lot more force than a nasty storm, which is something I would hope the blocking could withstand anyway.
The yard didn't have any problem with me doing it, at any rate, nor was I the only one there who had done so.
  #6
Old 05-22-2012
paulk's Avatar
paulk is on a distinguished road
They don't even want anyone on the boat when it's in the lifts. Going up up the mast then would be even worse. On the hard.... I would hope the blocking could withstand some leveraging force too, but I've never tried it, and have never seen anyone else try it either.
  #7
Old 05-22-2012
SchockT's Avatar
SchockT is on a distinguished road
I agree, going up the mast while on the hard would be no problem, but I wouldn't do it while in the slings even if the yard allowed it, which I doubt they would!
  #8
Old 05-23-2012
Capt Len is on a distinguished road
This may clean up the gene pool. Let'er rip.
chef2sail, smurphny and SloopJonB like this.
  #9
Old 05-23-2012
Minnewaska will become famous soon enough
Zero chance of our yard even allowing it. For good reason, IMO.
Jeanneau 54DS
  #10
Old 05-23-2012
Not in a travel lift, in a boat lift; the kind that stores the boat out of the water. The boat is 24 feet and weighs 4000 pounds.
You may post attachments
You may edit your posts
Boat lift: Okay For A Sailboat? Charrob General Discussion (sailing related) 10 09-10-2010 12:16 PM
Making a boat lift DePlano General Discussion (sailing related) 13 05-15-2008 07:27 PM
boat lift? dman Gear & Maintenance 0 04-11-2008 07:03 AM
Boat lift in a storm knothead General Discussion (sailing related) 5 08-27-2006 10:24 PM
anyone using a boat lift? DuaneIsing Gear & Maintenance 0 01-03-2003 08:25 AM
SEO by vBSEO 3.6.1
