Remove a captive pin - SailNet Community
post #1 of 9 Old 05-23-2012 Thread Starter
How do I remove a captive pin at the bottom of the forestay to change to a bolt supplied with a roller furler?
ben48 is offline
post #2 of 9 Old 05-23-2012
One of None
deniseO30's Avatar
Re: Remove a captive pin
Make, size, type, would help those trying to help you!
Most roller furler spools lift up so you can access the hardware they cover; if the sail is removed.
To remove the headstay;
Loosen the back stay and or the shrouds just enough to create slack in the headstay, allowing you to pull the "pin" Take note how many turns you loosened the turnbuckles so you can go back to the tension you had. To be safe, you want a halyard holding the mast forward just in case the mast wants to fall backwards and ruin your day.
My last project!
deniseO30 is offline
post #3 of 9 Old 05-23-2012 Thread Starter
Oday 27, profurl c290. Ive removed the forestay. I need to know how to remove the pin that connects the turnbuckle to the final u shaped bracket that attaches the turnbuckle to the stem.
ben48 is offline
post #4 of 9 Old 05-23-2012
One of None
deniseO30's Avatar
I found this at their site, english is also on the pages.
http://www.profurl.com/images/info_p...-light-101.pdf
Page 8 has the info you need (I think) good luck!
My last project!
post #5 of 9 Old 05-23-2012 Thread Starter
Thanks - I have the manual - it says to remove the captive pin. The pin has no head on it, no hole for cotter pin. It is solid, and stuck in place like grim death. I need to know how to drive it out, or if there is another way to remove it.
ben48 is offline
post #6 of 9 Old 05-23-2012
Pictures please.
Stumble is offline
post #7 of 9 Old 05-23-2012
What you have is probably part of the toggle and that pin will not come out. If this is the case, then you will need to get an eye end for the turnbuckle.
John
pics would help.
ccriders is offline
post #8 of 9 Old 05-23-2012
AdamLein's Avatar
Photos?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #9 of 9 Old 05-23-2012
Senior Cruiser
sea_hunter's Avatar
Relieve the backstay and shrouds and bob stay if you have one!
sea_hunter is offline
Speed/captive nut backing fiberglass? batkins61 Gear & Maintenance 2 05-26-2011 01:54 PM
My boat held captive by the housing crisis!!! SiXeVeN General Discussion (sailing related) 99 11-01-2008 05:43 AM
How to fix spinning captive nuts EO32 Gear & Maintenance 5 06-13-2008 05:02 PM
do i need to remove rudder to remove shaft 37cc jumpnkd Irwin 4 04-13-2008 10:48 AM
Remove name Mike pollock General Discussion (sailing related) 7 05-08-2006 03:32 PM
