How do I run My Mainsheet to BOTH sides of the cockpit? - SailNet Community
post #1 of 2 Old 05-26-2012 Thread Starter
NewportNewbie's Avatar
OK..I have a few threads knd of related to tho question. so I want to see if maybe I am not being clear or not asking properly...So I want to reroute my mainsheet.Currently its above the companionway. If I close the companionway door, I cannot operate the mainsheet. I plan on installing a gauge pod over the companionway, so I want that area clear of all lines. If I just reroute it to one side, my fear is that it will not work well if I am singlehanded and on the other side of the cockpit. Maybe that will be a non issue depending on how I route it...maybe reroute and just make it slightly off center? If I wanted it on both sides...whats the easiest way? I do not want to have to use a winch. I want the same operation, just from the sides...has anyone done this on their boat??
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 2 Old 05-27-2012
Re: How do I run My Mainsheet to BOTH sides of the cockpit?
Mine has a double block under the boom, another on the cabintop. No winches. You can double end your mainsheet, with a cleat on each side deck. Two separate blocks (or a double) on the boom, three singles on the cabintop. One midships, a turning block either side. Google "Double Ended Mainsheet" for ideas and diagrams. The ends of the sheet each become the working end, the other being made fast.
WanderingStar is offline
Best way to switch sides davidpm Seamanship & Navigation 10 11-09-2011 12:59 PM
Supreme Court Sides With Tiverton YC SOUNDBOUNDER General Discussion (sailing related) 4 04-02-2011 09:56 PM
Scary situation for both sides rikhall General Discussion (sailing related) 139 12-08-2010 04:56 PM
PSC 27: Re-routing the mainsheet forward and then to the cockpit BReach Pacific Seacraft 2 11-11-2010 09:45 PM
Varnish on both sides? geary126 Gear & Maintenance 2 07-09-2007 04:39 PM
