-   -   chain plates (http://www.sailnet.com/forums/general-discussion-sailing-related/87875-chain-plates.html)
Bob142 05-27-2012 03:18 PM
chain plates
I have recently acquired a Maple Leaf 48 and am looking for information as to how the chain plates are secured...
SchockT 05-27-2012 08:45 PM
Re: chain plates
It depends on the boat, but usually they are bolted to the bulhead inside the boat. Try posting pics of them outside and in, and we can probably figure it out.
Bob142 05-28-2012 11:02 AM
Re: chain plates
I have just been lurking on this site for the last month...so haven't figured out how to post pictures...
Bob142 06-13-2012 02:43 AM
Re: chain plates
Finally got pics...best I could pet on the underside...I hope there is more holding then this bit of fiberglass ...
https://www.dropbox.com/sh/dgaxkjiysx4qbvq/TIlkaexhh9
tommays 06-13-2012 09:12 AM
Re: chain plates
https://photos-4.dropbox.com/si/tbd/...G?size=800x600
https://photos-3.dropbox.com/si/tbd/...G?size=800x600
That looks pretty hard to remove and service :eek:
The closed body turnbuckels are also a time bomb as any issues are hidden inside them
Faster 06-13-2012 10:23 AM
Re: chain plates
Yikes... looks like you've got yourself a bit of a project there.
I think you need to remove more interior insulation etc to get a real picture of what's going on there.. Hard to believe they are relying on simply a large, glassed-over backing plate. The cracks in the deck around the chain plate are not exactly encouraging either...
erps 06-13-2012 10:54 AM
Re: chain plates
It looks like the chain plates are welded to a plate of some sort. We have the same sort of setup on our boat. I'm slowly getting access to each backing plate on the inside of the boat. Before we go off shore, I'll need some time and dry weather to disconnect all the standing rigging and pound the suckers through the deck so they can be redone. That should be a lot of fun. :(
Stumble 06-13-2012 04:21 PM
Re: chain plates
I would really suggest getting those chain plates removed and dye tested for crevice corrosion. It's not a particularly hard job once you figure out how to disconnect them from the inside of the boat. The fiberglass on the pics though looks saturated with water. If that's the case, you can almost bet that the stainless will be heavily corroded.
Bob142 06-14-2012 01:33 AM
Re: chain plates
Those are my thoughts...When I don't see big shiny strips and lots of bolts...those cracks make me very nervous...
