PORTA POTTI - A 'no no' or 'okay' for cruising? - Page 5 - SailNet Community
 14Likes
post #41 of 45 Old 05-30-2012
casey1999's Avatar
Re: PORTA POTTI - A 'no no' or 'okay' for cruising?
The mind boggles ....
Prolly need a slightly bigger boat though .... not to mention redesigned boat shoes.
Ok, here is the boat (built by Noah), it's up to you to install the rig...
QJL3CAE9V13ACA8E1ESKCAO1AQY3CA6RODYVCA3Z0OXWCA68H5OGCA1H9KYICANE6ES0CAGGEO7ACA81SD29CA0V4OIWCAF1.jpg
casey1999 is offline
post #42 of 45 Old 05-30-2012
bljones's Avatar
and you think a holding tank is odiferous. That is gonna be one stinky old shoe.
It's 5 o'clock somewhere:
bljones is offline
post #43 of 45 Old 05-30-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
and a holding tank would probably go better to windward ...
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #44 of 45 Old 05-31-2012
Caribbean Surveyor
canadianseamonkey's Avatar
Re: Haven't used a PortaPot in a few years, but
Originally Posted by casey1999 View Post
Sorry, we got too many lawyers in the US:
USCG Systems Engineering Division (CG-ENG-3)
Your direct discharge head is illegal in the US and you can get fined heftly. My understanding even if you lock your heads seacock shut it is still illegal in the US (US Coast Guard states a permantently installed head must meet their regs).. If you are a foreign boat passing through I think you'll be ok.
This is from the above Coast Guard link:
"Portable toilets.
Vessels having no installed toilet are not subject to the provisions of Section 312 of the Act. Portable toilets or porta-potties that use no installed water, power, etc., are not considered installed toilets and therefore not subject to the requirements in 33 CFR Part 159. However, regulations still exist to prohibit disposal of raw sewage within U.S. territorial waters, the Great Lakes, and navigable rivers. Use of portable toilets in combination with a direct discharge toilet is not permitted. Vessel owners may elect to remove installed toilets and use instead portable toilets. For vessels having a portable toilet, all non-compliant fixed toilets should be removed unless impractical or unsafe in which case such devices should be rendered permanently inoperable. For inspected vessels using portable systems, use only devices manufactured of a durable material, such as molded plastic, aluminum, etc., to facilitate removal ashore, securely fastened to the vessel using straps, wooden framing, or similar materials, and maintained by the vessel operator following the manufacturers instructions as to waste disposal, chemical additives, etc. "
Actually there are some (but not all) porta poties that are Coast Guard approved type III msd.
Porta Potti & Portable Toilets - Wholesale Marine
Same rules apply in Canada. I had called the Canadian Coast Guard about the porta potti question a few years ago and was told they are illegal unless permanently installed.
I don't get why people would use that in a boat. They stink and are messy. We had one in our cottage and I hated it...never mind in a boat.
canadianseamonkey is offline
post #45 of 45 Old 05-31-2012
Over Hill Sailing Club
smurphny's Avatar
This discussion definitely has a male/female element to it. I know the average female of our species does not like porta-potties or anything that does not look like the tiled, palatial toilet at home... and if it smells, well, just forget it. A friend of mine spent a LOT of money putting in a head that his wife would actually consider using. I worry about the opposite sex holding it so long, trying to avoid using the porta-pottie, that they may do some kind of internal damage. On the other hand, most males couldn't really give a hoot, (or a crap) about the facilities. A bucket? No problem.
smurphny is offline
Chaninging from Porta-Potti to pump out cb32863 Gear & Maintenance 13 06-01-2012 03:58 AM
Porta Bote lancelot9898 Gear & Maintenance 8 03-03-2009 03:42 AM
Block Island, RI & a porta potti kwf05001 Cruising & Liveaboard Forum 11 04-24-2008 03:17 PM
Head or porta-pottie? Jotun Boat Review and Purchase Forum 12 11-29-2006 06:34 PM
porta potties? jbarros Gear & Maintenance 6 01-02-2003 07:41 AM
