Homemade solar panel bracket for under $40... - SailNet Community
 6Likes
post #1 of 12 Old 05-29-2012 Thread Starter
travlin-easy's Avatar
After purchasing a solar panel for the boat I came to the stark realization that a commercially made bracket for it would cost more than the panel itself. In fact, some that I found cost nearly $350 and it didn't appear that sturdy. Being somewhat creative (old folks have to be creative cause we're always broke) I sat down and designed an adjustable bracket that would mount on any, relatively straight segment of rail. Something that was sturdy, stainless, and wouldn't cost an arm and a leg. Here's what I came up with:
All of the parts were purchased online and were really inexpensive. The only part that was not purchased online was the two short sections of stainless steel tubing, which I procured from a shop that makes Bimini tops. They were scraps that he donated to the cause.
Cheers,
Gary
travlin-easy is offline
post #2 of 12 Old 05-29-2012
No more curry buffets
Ritchard's Avatar
Re: Homemade solar panel bracket for under $40...
Nice. You wouldn't be Scottish by any chance?
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #3 of 12 Old 05-29-2012
Scots are cheap, he is frugal
Great job, and thanks for sharing. That type of practicality is right up my alley.
Why are people happy to accept science which makes their life easier while rejecting science that makes their faith or beliefs more difficult?
cupper3 is offline
post #4 of 12 Old 05-29-2012
chef2sail's Avatar
Good job Gary. You gave me inspiration for my panel project next year.
Its low so windage will be no issue, but Is it high enough so as not to block your stern running lights visability?
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 12 Old 05-29-2012 Thread Starter
No problem with the stern light, Dave. The only way it would be blocked is if you were directly above the light and looking down upon it. One of the other guys at the marina asked the same question so I turned on the running lights and had him walk around the boat and look from all angles--no problems at all.
Cheers,
Gary
post #6 of 12 Old 05-29-2012
Over Hill Sailing Club
smurphny's Avatar
Another cheap, sorry, frugal way : Mounted mine using an old concrete bullfloat joint: heavy duty aluminum, adjustable, and cheap. If it had a "marine" price tag, would probably cost $200. I think you can get 'em new for around $40 from any tool store.
Jgbrown likes this.
smurphny is offline
post #7 of 12 Old 05-29-2012
bljones's Avatar
Very clever, Gary. I like the inherent stiffness of having the end fittings installed 90 degrees to each other- elegant and simple.
It's 5 o'clock somewhere:
bljones is offline
post #8 of 12 Old 05-29-2012
Learning the HARD way...
eherlihy's Avatar
Excellent design... Why did you not post to Low Buck projects?
eherlihy is offline
post #9 of 12 Old 05-29-2012
the pointy end is the bow
erps's Avatar
What a coincidence! I just bought some used ends today to make an adjustable bracket for my solar panels. We have a boat store in town that sells a lot of used stuff as well. Picked up 4 of those bimini ends for $2 each and he has some used 1" tubing he'll sell me as soon as I get the measurements. Preliminary investigation indicates I'll be able to slide a piece of 7/8th tubing inside a piece of 1" tubing so I can adjust my panels at a 45' angle or horizontal. My panels are mounted on tubing off my life lines and I've been swinging them out and then tying them off with a piece of line to my bimini top but I want to be able to pole them out with a piece of tubing for support below. I love additional ideas to save money. Thanks for posting.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #10 of 12 Old 05-29-2012
Crotchety Old Member
tomperanteau's Avatar
And I have three that I need to mount. Thanks!!
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
solar panel QuickMick Gear & Maintenance 15 01-18-2016 05:36 PM
Homemade Solar Panels Capt Psycho SailNet FAQ 11 10-13-2011 11:14 AM
B32 & Solar Panel Dcneuro Bristol 2 07-26-2007 11:56 AM
solar panel maestro Gear & Maintenance 3 11-20-2002 12:02 PM
