Should I wire my radio and clock to constant battery? - SailNet Community
 2Likes
  • 2 Post By Maine Sail
post #1 of 10 Old 05-29-2012 Thread Starter
NewportNewbie's Avatar
Just going through the audio system and up to now I have not needed to have the clock and settings of the radio stored. Now I am using an Aux in and its a pain to program the Aux in as well as have the Eq's set for the acoustics of the boat, I kinda want it to remember the settings. Should I wire the radio like a car stereo where my yellow is hooked up to constant power? Is it too much of a load on the batteries? I have shore power so I can stay charged, no problem....but when sailing? I'd hate to be sailing all day and can't start because my radio was keeping the memory....I have a deep cycle and a starting battery system....Im pretty sure it won't be an issue....ideas?
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 10 Old 05-29-2012
travlin-easy's Avatar
Re: Should I wire my radio and clock to constant battery?
While the amount of battery drain from the radio will not be more than a few milliamperes, the problem is that it is a constant drain on the battery, therefore, the dockside charger will be constantly charging the battery(s) to offset the drain. This will ultimately shorten your battery life, but by how much I really don't know.
Good Luck,
Gary
travlin-easy is offline
post #3 of 10 Old 05-29-2012
Maine Sail's Avatar
Here's a random stereo I connected to see what the mA load was.
.007A X 24 =.168 Ah's per day
.168 X 7 = 1.18 Ah's per week
1.18 Ah's X 5 weeks = 5.88 Ah's per month......
The self discharge on a wet cell battery in a hot climate is worse than the memory draw.
At 5 weeks a 100Ah battery bank would still be at 94.2% state of charge, if there was no self discharge...
At 5 weeks a 200Ah battery bank would still be at 97.1% state of charge, if there was no self discharge...!!
This is like a wrist watch load to a house bank...
Stereo memory is a non-issue for any bank that is used as a deep cycle house bank. Especially on a boat that actually gets used.. Newer stereos are even more efficient and I've measured them as low as .002A... That's just 1.68Ah's per 5 weeks/month...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 10 Old 05-29-2012
The clock uses very little power. I would have an off switch for the hot lead as the radio powered up will draw down a battery in a few days, even if not playing.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #5 of 10 Old 05-29-2012
Wandering Aimlessly
PBzeer's Avatar
I can't give you any exact figures, I can only say is it hasn't been a problem for me.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #6 of 10 Old 05-29-2012 Thread Starter
Sweet. Right now it's all connected to switched power. I never used it much because it sounded like crap and it was connected to a CD changer. Who uses CDs anymore??? So I bought an $11 cable that plugs my iPhone I to the CD changer input and charges the iPhone as well. It's just you have to switch the aux in on. So u did then I set the eq and to my surprise the audio was amazing. I wondered why the previous owner never dialed it in. Until I went back and all settings were erased. Ahhh. Then I thought maybe they did that for a reason. So I thought I would ask. It's virtually no drain for clock and memory on the battery. I'll keep the main power to switched. Thx guys. I do use my boat about 3 days a week.
post #7 of 10 Old 05-29-2012
chef2sail's Avatar
I have mine wired direct. Long as it goes on your check list when leaving the boat for more than 1 day to make sure the stero itself is turned off you will be ok. Its on my checklist after turning the DC master switch on my panel off.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #8 of 10 Old 05-29-2012
asdf38's Avatar
Mainesail did the math but if it isn't a problem for a car it's not going to be a problem for the boat.
asdf38 is offline
post #9 of 10 Old 05-29-2012
KnottyGurl's Avatar
I suppose now would be a good reason to have a house bank and a starter bank, this way you will never have a problem with starting.
And you will always have music too.
If your charging system is not automatic from say 10amp to 2 amp auto switching and sensing then upgrading will be a good idea, everything runs from the batterys, lights, radios, stereos so it will always be a draw, if you only need a trikle charge and your delivering a full charge then that could be an issue. If your not in a position to upgrade then turn the charger off during the days your there and back on when you leave so it gets a better cycle.
Sailing The Great Lakes in my "Bluewater" Grampian 26
KnottyGurl is offline
post #10 of 10 Old 05-30-2012
Maine Sail's Avatar
It is frustrating the amount of misunderstanding I see and come across regarding chargers, but, it is understandable given the buying habits of many sailors when it comes to chargers. Folks tend to put all kinds of thought into "what batteries should I buy", threads up the whazooo here about just that but barely ever a thread on how to buy a good charger.
ALL CHARGERS ARE NOT CREATED EQUAL
There is LOTS of junk out there that can kill your batteries.
A good marine charger, emphasis on marine, should never over charge a battery. It should ideally, at a minimum, have three stages for charging; bulk / constant current, absorption voltage and float voltages. It would preferably have a fourth and fifth stage as well, equalization and cyclic absorption for wet cells to prevent stratification.
Ideally I would LOVE to see every boater buy a battery charger that incorporates a battery temp sensor that mounts directly to the battery but these are pipe dreams. A charge voltage that is correct at 80F will be far to high at 100F and will eventually ruin the bank..
"But my batteries never get above 80F."
Consider the large J boat I worked on last summer who was on his third set of AGM batteries in 4 years. That is over $3400.00 in batteries!!! A $300.00 charger with temp compensation would have gone a long way towards helping the situation.
The batts are behind the stbd settee and under the stbd side nav seat. The hull is flag blue and at mid day the temp inside the battery compartment exceeded 110F, IN MAINE...... His charger was NOT temp compensated....
I am at a loss as to why I see folks spend hundreds, and thousands of dollars, on batteries then try to feed them with the cheapest Wal*Mart, Sears or other "cheap" automotive type of charger, not saying folks here are doing that, but I see it day in day out in the "real world"..
I just had another bank less than 1 year old ruined by a cheap Schumacher Ship-n-Shore charger. I am now at over 5 banks ruined by Schumacher Ship-n-Shore chargers and one of them was a 2k GEL cell bank that was being fed over 15 volts on the GEL SETTING!!!!!!!!!! THESE ARE NOT MARINE CHARGERS despite the glossy marketing... Buyer beware!!!
Decent quality marine chargers will have brand names like; Xantrex, Guest, Newmar, Charles, Pro-Mariner, Sterling, Victron, Mastervolt etc.. They will not have a Die Hard or Schumacher sticker....
A good marine charger will not over charge batteries. It is not the charge current that "over charges", because current is dictated by the battery at a specific voltage. Current acceptance is dictated by the battery not the charger. Chargers don't "force" current into a battery the battery takes what it needs up to what the charger can supply. I have a battery on my bench right now taking less than .04A of charge current at 13.4V. It is being fed by a 40A charger.... The battery only wants .04A to maintain 13.4V so that is what the charger supplies.
What over charges batteries are incorrect voltages held at an incorrect level for too long or at the wrong temperature.. Voltage is pressure so a voltage too high, for too long, will increase the acceptance enough to boil off electrolyte once the batteries have become "full". This is why a float feature, float is a lower maintenance voltage, is very important. A good charger will remain in float while light loads are used.
Leaving a charger plugged in while away from the boat when it is at a marina is an area I'm not going to get into. Suffice it to say many chargers that fail are caused to fail by the HORRIBLE power available at most marinas. When they fail they can often take out the bank with them thus the charger gets the bad rap not the marina's power supply that caused the whole mess..
I have found that the newer "world voltage" chargers such as the Pro-Mariner Pronautic P and Sterling Pro-Charge Ultra (these are the same charger under different brands developed in partnership) deal with these fluctuating voltages far better than US only voltage chargers. Many brands now offer "world voltage" chargers.
A good charger is money well spent. A cheap charger is most often working against you and will nearly always bite you in the end.
Features worth considering:
*UL 1236 or ABYC Compliant
*Multiple programs for charging
*A user customizable charge program
*Equalization mode
*Repeat absorption mode (to prevent stratification in wet cells)
*Temp sensing (at the battery not the air around the charger)
*World Voltage capable 90V-260V & 40-80hz
*Warranty - some quality chargers are coming with a 5 year warranty!!
TomMcGuire and chef2sail like this.
______
Battery Interconnects Wire Size With Inverter efiste General Discussion (sailing related) 0 05-04-2012 12:30 AM
Battery on a VHF radio? L124C Gear & Maintenance 5 03-08-2012 02:28 PM
Radio battery backup FastbackFill Gear & Maintenance 13 12-17-2011 03:12 PM
wire size from battery to key switch ekenna Gear & Maintenance 12 03-25-2010 11:16 PM
Wire size between Battery and System? Perithead Gear & Maintenance 5 01-02-2008 12:00 AM
