How Far Do You Heel...? - Page 6 - SailNet Community
 34Likes
post #51 of 90 Old 09-03-2013
grumpy old man
Re: How Far Do You Heel...?
That's a fine vessel Jeff. I could enjoy that boat at any heel angle.
Bob's Blog ....
bobperry is offline
post #52 of 90 Old 09-03-2013
Moderator
Jeff_H's Avatar
Coming from you that means a lot. If you find yourself near Annapolis, I would be delighted to sail with you.
Jeff_H is online now
post #53 of 90 Old 09-03-2013
grumpy old man
Yeah but,,,,your water is so thin it scares me. I've sailed there. It's terrifying.
Count on it Jeff.
Bob's Blog ....
bobperry is offline
post #54 of 90 Old 09-03-2013
Moderator
Jeff_H's Avatar
Count on it Jeff.
Especially terrifying in a one of those new fangled fragile fiberglass thangs....
post #55 of 90 Old 09-03-2013
Although 30 is fun as we berry the rail..but usually 15 to 18 work best for my full keel
fatcatsailor is offline
post #56 of 90 Old 09-04-2013
add a pinch more backstay
Would this not induce more weather helm Jeff?
ScottUK is offline
post #57 of 90 Old 09-04-2013
4KSB driver.
SHNOOL's Avatar
To BobP... I think we agree more than we disagree. Certainly about heel angle.
Regardless to the OP... experiment with what is most efficient with your boat for any particular wind... push the boat (when you are comfortable), but do so only with respect to crew!
These boats can usually take more of a beating that we can!
bobperry likes this.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #58 of 90 Old 09-04-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
going on the "depends on the boat" It also depends on when the boat was designed and built. Most Alberg and the like are very "wet" in that they like to heel over. This was designed in as a way to make the boat longer as your speed in the water is determined in part by your length at the waterline. Boats with long overhangs get longer the further they heel.
More modern boats with plumb bows and reverse transoms don't need to heel to go faster, they generally seem to sail more upright (and go like hell compared to us old full keelers).
I am unsure on the transitional years
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #59 of 90 Old 09-04-2013
chucklesR's Avatar
Since now I'm sailing a monohull I find that past 20 degrees makes my non-gimballed cup holders less efficient if holding a full rum and coke.
Therefore, from a performance and efficiency point of view I tend to keep my heel below 20 degrees by trimming the sails with the iron genny.
tspooner, olddog60 and blutoyz like this.
chucklesR is offline
post #60 of 90 Old 09-04-2013
grumpy old man
Machine:
That's the traditional theory anyway. But the next time you are heeled over look over the bow and the stern and see just how much of your boat is immersed. If it's not in the water it's not doing anything to extend the sailing length. This effect or imagined effect is over rated. I don't care that it has been standard theory for years. Overhangs are the result of old rating rules and are marginally effective at best.
Bob's Blog ....
bobperry is offline
Crealock 37 heel and sea comfort swiftibis Pacific Seacraft 13 01-23-2012 02:21 PM
How far can I heel over? Will I tip? Shadbjohnson Learning to Sail 16 09-05-2011 02:38 PM
Excess Heel HuskerDave Seamanship & Navigation 29 10-20-2008 05:36 PM
Minimizing the Heel Mark Matthews Learning to Sail Articles 0 10-24-2001 08:00 PM
