Slip from Hell... - Page 3 - SailNet Community
 15Likes
post #21 of 25 Old 06-05-2012
1975 Newport 28
jaschrumpf's Avatar
Re: Slip from Hell...
Personally, I cringe when I see a boat buddy ready to "help" me dock. I am usually always single handing, and I have a system I follow when I back in. The last time someone "helped" me, he was standing by on the finger dock (port side) of my slip with my starboard side stern line (the last line I put on). I tossed him the line I wanted put on first, and he dropped it into the water, and then tossed me another line that was handy... my port spring line, which is no damn good for tying me to the dock.
The breeze pushed me away from the dock to where my port stern line wouldn't reach him and toward the next boat in the slip. I've strung lines between the pilings, so I was able to grab the upwind side with the boat hook and drag myself back, but it was a clusterdocking and it looked like I'd never done it before.
So that's it for dockside help for me. I'm just going to wave 'em off with a "Thanks anyway!" and go through my routine.
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #22 of 25 Old 06-05-2012
chef2sail's Avatar
T37chefs slip was a "Houdini" slip for sure. I have seen it. sEems likkme they should put a PB in it.
JAScrumpf- The poeple in our club know how to help with doick lines as they have sailboats also. I also do a lot of siglehanding. Once I get my midhip spring line on ( my first line on and last off) there is nothing they can really do to hurt.
My problem is notpeople okn the dock, but guests on the boat who want to help. I usually have to have them just sit down and let me bring her in.
Dave
T37Chef likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #23 of 25 Old 06-05-2012
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by T37Chef View Post
Nay...I think I got you beat
Wow. That's some slip. I'm impressed. I think I'm a good boat handler but that slip, especially with the cat in place and the prospect of a boat on the opposing pier is intimidating. I'm going to print a copy of those photos and bring them to the MYC 'vous to talk about.
Bingo. One of the briefing points for crew before bringing a boat into the dock is to remind them who is in charge. It is NOT the person standing on the dock. No one passes a line ashore without my say so. I don't want bows pulled in or sterns dragged into docks.
Routines are good. They are routines because they work.
Please don't get me started on bow thrusters. *grin*
It takes longer to brief crew than to bring the boat in.
I generally back into slips and when I do have crew it amazes me how hard it is for some crew to understand that the place for the person assigned to a bow line is in the stern. *sigh* Clearly a failure to communicate on my part but I'll keep trying.
SVAuspicious is offline
post #24 of 25 Old 06-05-2012
TakeFive's Avatar
Originally Posted by Capt-T View Post
Maybe work on your backing skills?? ...Hey... I didn't say it was a "good" solution!!
Actually, backing up a wing or fin keel boat (not a full keel) is a great solution, especially since the OP has an outboard. A hard link is not required, but greatly increases maneuverability at slow speed. Here's mine. I have wheel steering, but this could work just fine with a tiller:
I back up most of the time when transiting my fairway. When you go forward, your stern swings out, which wreaks havoc in confined spaces like OP has. Going in reverse, the boat swivels about her keel, and it's much like driving a car. Since I have a wheel, I actually stand in front of the wheel facing backwards. Standing in front of a tiller would work just fine too.
I back into my slip because the finger piers are not long enough to board into the cockpit when pulling front-in, and my bow is too high to board there. Backing in might make things easier for the OP getting in, but pulling in forward works fine too. Either way, I'd strongly suggest backing out of the slip. If you pull in forward (like shown in the OP's picture), just back out and steer the rudder-motor appropriately. Don't try to change direction in the confines of the marina - go all the way out of the marina before changing directions. If you pull in backward instead, walk your boat along the wall until you're out of the slip, give a good hard push to your stern to get the boat twisting in the right direction, and put in reverse with rudder (and preferably motor) hard to starboard. Prior to doing this, you could also move the stern out with a spring line to the bow, motor in forward with rudder and motor to port. This would push your stern out, from which you could then reverse out of the marina.
I have some tight confines and very tricky tidal currents, which require me to use reverse for all my docking (regardless of current direction), and half of my departing (when the current is pushing me into the boats across the fairway). I just filmed some videos of this, so maybe they will give you some ideas:
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #25 of 25 Old 06-05-2012
sevseasail's Avatar
Originally Posted by CaptainForce View Post
I had a near identical slip for years and I grew to like it. My plan was to enter the slip with a couple of fenders deployed on my port side and take the bow to the empty corner behind my slip. Here, I would step off the bow with an aft spring and a bow line in hand. It was simple to shove the bow back out and pull the stern in. I found, with the fenders in place, I could easily walk the boat back into the slip. When departing, having the bow pointed out, I kept a line from the bow to a warp around the starboard piling. By releasing this line last, I could turn into the wind if necessary, and easily motor out.
I like that... that's how I will do it (now that you have explained it....)
S/V Chata
1980 Catalina 22
"Common sense is the least common of the senses"
sevseasail is offline
What the hell did I just do!?!? xymotic Introduce Yourself 3 09-01-2011 07:33 PM
ASA 101. Hell yes. RatHatDiver Learning to Sail 22 08-11-2011 10:13 PM
What the hell? eherlihy General Discussion (sailing related) 16 07-19-2011 08:28 AM
Slip Sub-Lease via Slip Renter KeelHaulin General Discussion (sailing related) 4 06-26-2007 12:50 AM
