Could You Survive a Collision - Page 2 - SailNet Community
post #11 of 15 Old 06-07-2012
Re: Could You Survive a Collision
Things like this will seriously curtail night sailing. We try to keep a good watch but this could ruin your whole day.
s/v Odyssey
Catalina 30
glassdad is offline
post #12 of 15 Old 06-07-2012
I believe I and my boat would survive the collision, although probably with some serious damage. My boat is small and the speed of impact would likely be less than 6 knots. It's an Etap, with two hulls, and foam filling between. A large volume of foam is in the bow under the vee berth, so a lot of the collision energy would get absorbed there. If the outer and inner hull are both penetrated we still won't sink, there's 100% foam flotation. Please don't start telling me how the foam absorbs water! The rudder with a large hole from ice and immersed on a mooring for 25 years had dry foam when I dug it all out.
Gary H. Lucas
GaryHLucas is offline
post #13 of 15 Old 06-08-2012 Thread Starter
casey1999's Avatar
Read article in paper last night. That floating pier weighs 165 Tons.
casey1999 is offline
post #14 of 15 Old 06-08-2012
Send a message via AIM to HPLou
Usually don't try to hit the dock, normally come up to it easily and then tie up.
HPLou is offline
post #15 of 15 Old 06-08-2012
Absolutely! My 31 ft steel origami hull is 3/16th plate. I have already T-boned a concrete dock, and one of my 36 footers , of the same thickness, sailing at hull speed, has already T boned a steel barge, which was tied to the dock, with zero damage . Another hit a submerged barge , on a sharp corner, doing hull speed. He caught the corner of the barge , just off the centreline, at the bow. Zero damage, except some scraped hull paint.
Brent Swain is offline
Sometimes it's just luck if you survive davidpm Seamanship & Navigation 34 10-05-2009 11:49 AM
3 Survive Floating 30 Hours In Ocean - Local6.com NewsReader News Feeds 0 04-09-2007 12:15 AM
Eagles survive scare (The Charleston Gazette) NewsReader News Feeds 0 03-01-2007 01:15 AM
Tips to survive a hurricane dazeoff Seamanship & Navigation 2 02-05-2001 05:15 AM
