Looks good, how well will she sail? - Page 5 - SailNet Community
 8Likes
post #41 of 53 Old 06-21-2012
beiland's Avatar
Re: Looks good, how well will she sail?
Originally Posted by yossarian View Post
I absolutely don't have the experience to say how a boat will sail based on hull/keel shape. But I have a different question: What's up with the sail plan? Is it common to have a "ketch" rigged boat without a mainsail? Does anyone have other examples of a two masted boat where the main mast serves only to support foresails?
"Conventional booms excessively flatten the foot of the mainsail, and are often oversheeted, contributing significantly to the leeway forces. I once had a copy of a test on a Morgan 41' Out Island ketch , where upon removing the mainsail, the boat lost only 1/2 knot of speed, but cut its leeway in half (from 11 to 6 degrees). A staysail was then rigged between the masts in place of the mainsail, and the boat regained 1 knot of speed while retaining its decreased leeway."
Sail Propulsion - Revisiting a Mast-Aft Sailing Rig
Mainless Tayana 55
Aftmast rigs??? - Page 3 - Boat Design Forums
beiland is offline
post #42 of 53 Old 06-21-2012
beiland's Avatar
Agree with everything but the price - it's a 60 footer. Feathering props for it will be over $3K EACH. Even folders will be getting there.
Edit: Just reread the ad - it has contra-rotating hydraulic feathering props - about as nice a setup as there is.
That's the same thing I read about her props. Whoever had her built did not skimp on the money.
beiland is offline
post #43 of 53 Old 06-21-2012
beiland's Avatar
Motorsailng synergy
Originally Posted by wallabycreek View Post
I have personally sailed 100,000 sea miles. I love that boat. She would go anywhere in any weather. For me upwind speed is not even any consideration at all. I strongly suggest that you do not buy her and then start chopping her around. She looks to be a great boat. Take her for a run around the world and enjoy her for what she is. Read the "Around The World Sailing Guide" on kindle.
I agree if you intend to go cruising.
Personally I think she has adaquate sail area to perform at monohull speeds.
And you might just think of her as a good motorsailer:
"And in light airs, running one engine often is all that is needed to bring the apparent wind forward to make the sails work harder and the combination provides much better results than either motoring or sailing alone."
beiland is offline
post #44 of 53 Old 06-21-2012
beiland's Avatar
Originally Posted by paulk View Post
Your post questioning this boat's sailing qualities doesn't give us the information we need to answer it properly. What are you buying it for? A liveaboard on Lake Union? Might be great. 'Round the world, short-handed, in the Trades - looks like that's what she was designed to do. Mid-week 'round the buoys racing in Puget Sound? Not so much. There are some red flags in the listing that suggest some expensive issues besides the teak decks. If the boat is aluminum, why are they having trouble with gelcoat blisters? Several of the photos refer to gelcoat repairs in the topsides and elsewhare. If the aluminum was fiberglassed over (Why 'glass over aluminum?? Was it leaking because of electrolysis??) and there are now blisters in various places, delamination is likely happening all over the boat where salt water has gotten in and where the fiberglass is keeping it snug up to the aluminum... This boat is a handful. Do you expect to have paid hands, or do you have four children who enjoy learning yacht maintenance?
I'm just reading thru this subject thread and posting as I go along.
I was wandering this same thing also? I thought I better go back and see whether this vessel was built of alum or glass??...confusing descriptions
beiland is offline
post #45 of 53 Old 06-22-2012
TQA
Bombay Explorer 44
TQA's Avatar
Looks ali to me and that would fit with it being built at Huismans and fitted out at Moodies. Big comfortable liveaboard that would do just fine on a milk run circumnavigation IMHO.
BUT lots of 36 year old systems just waiting to break down and require replacement AND a tired looking teak deck. Needs someone with deep pockets.
TQA is offline
post #46 of 53 Old 08-07-2012
grumpy old man
Looks to me like that boat would have decent performance for a heavy, moderate draft cruising boat. Performance will be sedate but with good sails and some skill trimming them the boat should go to weather with an optimum apparent wind angle of around 37.23 degrees. That's not "close winded" but it will get you there and it's typical of boats of this type.
When you get advice from a friend try to get a handle on what the friend is using as a benchmark for "performance". If he is using a modern race boat or a sport boat then this LG design will be a pig. If he is using a Taswell or a Hylas then I think this boat would be in the same performance category.
Bob's Blog ....
bobperry is offline
post #47 of 53 Old 08-07-2012 Thread Starter
What is the closest close-hauled angle (ballpark figure) for most of the well performing types of performance cruisers? I am trying to evaluate performance cruisers that are sloop rigged vs cutters vs Ketches in the 40 to 46 ft range.
As I understand it, a Ketch does not point very high. A sloop points highest, and a cutter is in between. Can a well trimmed ketch point pretty high, or is it no comparison to a sloop? Sam
Shamanic Bilgewater is offline
post #48 of 53 Old 08-07-2012
grumpy old man
Pretty hard to give you an accurate question tto so broad and general a question.
Consider:
Ketches are not all the same. Some sail very well and some don't.
Sloops are not all the same. Some sail very well and some don't.
Cutters are not all the same. Some sail very well and some don't.
But form the sake of staying with the stereotypes you are correct. The sloop will/can point higher than a cutter and a cutter will/can point higher than the ketch. But there are a lot of exceptions to this.
Figure a boat lie a Valiqant 4o will go to we4ather effectivekly with an apparebnt wind angle of 32 degrees if it is being sailed by a good sailor and the sails are in good shpe.
Then we can generalize to say a cutter flying two headais will point to an apparent wind angle of 36 degree and the ketch with mizzen up about the same, maybe 37 degrees depending on how you are trying to trim the mizzen. But there are some ketches out there that would struggle to point to 40 degrees apparent. In a breeze, with the mizzen boarded out or furled a good ketch should be able to point just as high as a sloop, all else being equal, i.e. hull shape, draft, displ, SA.
But I hate this approach. Boats are individuals and need to be evaluated specifically. There are too many variables to make the generalities applicable most of the time.
Bob's Blog ....
bobperry is offline
post #49 of 53 Old 08-07-2012 Thread Starter
I can't sea trial each boat I would like to, much less find comparable wind conditions from one trial to the next, so to narrow them down as far as upwind performance is concerned, is there any index that an extreme wannabe like myself can utilize for preparatory comparison shopping, an index which evaluates the theoretical, if not actual, upwind performance potentials of different boats? I would think that in this internet age, I could put into some database the identity of hull shape, and assume new sails and hardware upgrades as part of the baseline, and out would pop a happiness factor, along with best resale potential. Is that what all the I, J, P, E and the SA/D CWP MCR type abbreviation **** refers to, and do I have to learn all that ratio crap? Holy hell, I didn't finish high school algebra!
Wow, what a great idea for a website! Somebody who likes computers, get on that, make a performance comparison website for idiots and you'll be rich, and you can buy any boat that your website chooses.
And while I am on the subject, I want a performance cruiser with the best resale potential, because it seems the case that many of us get stuck not being able to resell the boat we fell in love with and bought, so a little resale sobriety check really out to be one of the top factors for making a purchase for the not super rich amoungst us.
Unfortunately, from what I can tell, some ordinary , but very pretty, boats that are wildly popular like Beneteaus, Catalinas and Jenneaus, well they don't look to me like classics that will hold their own over time.
Maybe some of them are, but there are just so darn many of them, the few special ones get lost in the blur.
If there are any real winners in that group, I mean stout ones, real ocean passage makers and not just floating living rooms, please someone let me know which ones fit more in the more serious category. They seem like they are made to look like giant living rooms to appeal to the wives, but they just go daysailing or maybe to Baja, and truck 'em back.
Are any of them as stout as they should be for ocean sailing? Maybe they resell better now as newish, but the Valiant that you mentioned and those similar older ones, the older ones with the teak below and the thicker fiberglass hulls, do any of them have good resale value still? Thanks for reading.
post #50 of 53 Old 08-08-2012
Moderator
Jeff_H's Avatar
There are several internet sources for the kind of information that you are asking about.
Carl's SailCalculatorPro Sail Calculator Pro v3.53 - 2500+ boats has a long list of makes and models with all of the numbers crunched.
PHRF ratings give some indicator of boat speed in relative seconds a mile. For example PHRF New England - Handicapping - Base Handicaps
Yachtworld.com has a lot of information on various models on the market.
As a broad generality, if well maintained, older cruising boats do tend to hold their value. If used regularly, and maintained and upgraded over time, an older boat can be a good way to go. That said, at some point the components of the boat begin to simply wear out, and many of the older designs out there give up a lot in terms of ease of handling, and or seaworthiness.
But as I look at this discussion, I really want to emphasize that I would respectfully suggest that you are going at this in way that makes things wildly more difficult for yourself. I strongly suggest that you take to the time to build skills and learn about your options rather than come here as a newcomer looking for advise and an impossibly large boat for a first boat. This is not meant as a put down. We all had to start somewhere. But starting with very large boats only makes your dream much harder and riskier.
I apologize that I wrote the following for another purpose but it addresses what I am saying in more detail:
The dream of voyaging under sail can be a powerful one. There was a period when several times a month I would receive an email from someone who is considering doing just what you are proposing. I have watched literally dozens of folks go through this. Some are successful in getting 'out there', some discover that they really enjoy sailing and find that they really have no need to 'go out there’; some have discovered that the sailing life is just not for them, and others have not even gotten past the dreaming stage.
From what I have seen, the most successful (especially when children are involved) have been the ones who have been somewhat systematic about going. There is a lot to learn before one can safely venture offshore. No one would assume that if they knew nothing about how to fly an airplane, they could buy a jet airliner take a few lessons and be able to fly around the world. I think most rational people would expect to start with a small plane and work their way up. But for some reason people assume that they can just go out and buy a big boat, take a couple lessons, read a few books, and then go safely cruising.
While there are people who literally have taken a few lessons, read a few books and went out cruising, those that were successful following that route are far more rare than those who have done some kind of apprenticeship. Learning to sail and learning to cruise involves a lot of knowledge and no matter how much you know, there will always be more to learn, but I suggest that you at least take the time to learn the basics, and that just about can’t happen if you buy ‘a big sailboat’ and move your family aboard.
I find myself saying this a lot lately but here I go again. We all come to sailing with our own specific needs, our own specific goals and our own specific capabilities. The neat thing about sailing is that we all don’t have to agree that there is only one right way to go sailing. There is no more truth in expecting that there is one universally right answer about many aspects of sailing than there is in trying to prove that vanilla ice cream is universally better than strawberry ice cream. One area of sailing for which there is no one universally right answer involves the amount of knowledge one requires to go sailing.
For some, all they need or want to know about sailing is just enough knowledge to safely leave the slip sail where they want and get back safely. There is nothing inherently wrong with that approach. Lack of knowledge will impact the level of risk, cost, comfort, and performance, but if you want to get out there with minimal knowledge it can be done. But for others, like myself, there is much more to sailing than simply developing a rudimentary knowledge of sailing basics. If you fall into that camp, it is next to impossible to learn to sail really well on a boat as large as the one in question.
While I am in no way suggesting that this makes sense for everyone, for those who really want to learn to sail well, I strongly suggest that they start out owning a used 23 to 27 foot, responsive, light-weight, tiller steered, fin keel/spade rudder (ideally fractionally rigged) sloop (or if they are athletically inclined then a dinghy.) Boats like these provide the kind of feedback that is so necessary to teach a newcomer how to really sail well. Boats like these have small enough loads on lines and the helm that you and your crew can all participate and learn together. Being able to learn and participate, the crew will be more engaged and less likely to be bored and feel kidnapped.
By sailing well, I mean understanding the nuances of boat handling and sail trim in a way that cannot be learned on a larger boat. Used small boats generally hold their values quite well so that after a year or even few years or so of learning, you should be able to get most of your money out of the small boat and move on to a bigger boat actually knowing something about which specific desirable characteristics of a boat appeal to you as an experienced sailor rather than the preferences of some stranger on some Internet discussion group. Any costs associated with buying and reselling a small boat, will be minimal when compared to repairing a big boat that gets beat up will a novice is learning to sail on too big a boat, and are way smaller than the costs incurred when an inexperienced sailor buys the boat of their dreams only to realize with experience that the boat of their dreams turns out to be a nightmare.
From the advice that you have already gotten you can tell that there will not be a consensus of opinion on how to go distance cruising. It is nearly impossible to learn to sail well on a the types of boats you are considering and without highly developed sailing skills, a boat that large is pretty dangerous offshore.
In any event, I think that you have the right idea about taking sailing lessons. If I were in your shoes, I would sit down and put together a list of all of the things that I would want to know before I set off voyaging such as:
Boat handling
Sail trim
Rules of the road
Weather
Routing
Boat husbandry, repair and maintenance
Diesel/ gas engine maintenance and repair
First aid
Heavy weather tactics
Legal restrictions on leaving and entering foreign countries
Navigation, (Piloting, Celestial, dead reckoning and electronic)
Provisioning
Radio operators license exam requirements
Safe and dangerous fish to eat
Sail trim
Survival skills
Etc………..
Once I had what I thought was a complete list, I would set up a schedule to try to develop those areas of skill that I was currently lacking. As much as possible I would try to involve all those crewmembers involved in as many of those aspects as each is capable of understanding. This process could take as little as a year, but more often takes two to three years. The process itself can be very rewarding and can build the kind of bonds that are required to be cast away on that oh-so-small island that a boat underway represents.
Respectfully,
dacap06 likes this.
Jeff_H is online now
Can someone recommend a good book/DVD on how to sail ? AquaBoi Learning to Sail 14 04-06-2010 03:19 PM
Looking for a good Sail Loft in MA/RI sailingdog Gear & Maintenance 10 07-03-2008 07:23 PM
Good Day Sail Areas kptmorgan04 Chesapeake Bay 4 05-23-2007 10:01 PM
What are good 'learn to sail' sites? mwer General Discussion (sailing related) 16 08-21-2006 08:26 AM
The Voyages of the Good Ship Jabulani: Finally under sail @ Sail Blogs NewsReader News Feeds 0 04-18-2006 03:15 PM
