Is she bluewater? Interesting story to help with these questions. - Page 3 - SailNet Community
 73Likes
post #21 of 126 Old 06-11-2012
Barquito
Barquito's Avatar
Re: Is she bluewater? Interesting story to help with these questions.
I wonder if the illness involved in this story was food poisoning.
Valiant 32
Barquito is offline
post #22 of 126 Old 06-11-2012
Interesting to note that even experienced delivery skippers can fall prey to unfounded rumours spread by "experts" at tiki bars all over the coast.
Sequitur
Here's a blog from a couple circumnavigating in style and comfort in a Hunter 49. They rounded Cape Horn last winter. They've had their share of the usual equipment problems, but, again, it's not the fault of the boat.
Sequitur likes this.
kbyte is offline
post #23 of 126 Old 06-11-2012 Thread Starter
@Barquito
I think they said his problem was related to some kind of tear on the esophagus? Don't know if the tear came after the fact or what. One thing I wonder tho, is what the hell do you do if you're single-handing something and get sick? I guess you're kinda screwed.
tes735 is offline
post #24 of 126 Old 06-11-2012
KIVALO's Avatar
Dock
I've had to work through a bout with flew before, it sucks.... ROYALLY!
Originally Posted by tes735 View Post
@Barquito
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
post #25 of 126 Old 06-12-2012
I'm in the market for a bluewater. Used to have a cal 25 for years and sailed around in Galveston bay until I moved inland and sold it. I've been reading forums like this for awhile doing research to see what my next boat should be and have seen the question of "what bluewater boat to get," and "what makes a boat bluewater" etc.
I take some much from a story like this, from "make everything heavy duty as possible," to "have backup parts for items you can't move without," to "double check that everything works!" to "do drills with gear to make sure it works in a pinch" and the list goes on.
By the way, because of forums like these, I think I've narrowed it down to one of the heavier boats like an Alberg based on my budget. Thanks to all those here for the wealth of info.
I've said it before, I'll say it again... IMHO, the single best resource for addressing these criteria is John Rousmaniere's DESIRABLE AND UNDESIRABLE CHARACTERISTICS OF OFFSHORE YACHTS...
Don't take too seriously the comments of those who may opine that there is no such thing as a bluewater boat, or that most any plastic fantastic can be "modified" or "beefed up" for bluewater sailing...
Some boats and designs simply ARE far more suitable than others or most for such sailing, it's completely beyond me why some try so hard to deny this...
CBinRI, SVAuspicious and RainDog like this.
JonEisberg is offline
post #26 of 126 Old 06-12-2012
SERIOUS SAILOR
JoeDiver's Avatar
It doesn't matter to me...the water in my lake is brown....so my Catalina 25 doesn't need to be bluewater capable...there isn't any blue water in Eagle Mountain Lake....sometimes it's green...by the end of summer...but usually it's brown.
Shortnsalty likes this.
1982 Catalina 25 #2897
FK/SR/Traditional
Eagle Mountain Lake, Texas
JoeDiver is offline
post #27 of 126 Old 06-12-2012
Lookin' for an excuse ...
CaptTony's Avatar
Which boats did you sail and what areas did you find lacking?
I owned a Hunter 27 and took it to the Bahamas twice. The list of problems is too long to get into here. The main problem was a rubber coupling between the propeller shaft and the engine. The rubber was just glued to two pieces of metal on either side. The lag bolted engine mount - that's right lag bolted into the fiberglass not through bolted with backing plates and nuts - came loose, the engine was out of line with the shaft and the coupling broke. This was many years ago and Hunter has since corrected this, but it is symptomatic of the way the boat was put together. Many things happened on those trips: the head failed, the radio stopped working, problems with the manual water pump and so on.
Then in the 90's I did a Hunter delivery of a 40 footer. We got into a storm just outside Beaufort heading north from Florida. The engine stopped in the rough seas (we were headed in to Beaufort and the wind was right on the nose). That was the end of the engine and it wasn't algae in the filters. We checked. Water was coming over the bow and soaked the cockpit. Water got into the installed instruments and took them out along with most of the onboard electronics. Water penetrated down below even though the hatches were secured. Other things happened to the interior, but I don't want to get into it in an open forum.
I had another Hunter delivery after that one but I turned it down.
I consider Hunter and Catalina in the same class of boats. I delivered a couple of Catalina's with no problems, but the conditions were near perfect. Still, perhaps it was wrong to criticize Catalina the way I did with no personal knowledge of critical failures. So, I take back what I said about Catalinas and defer to what Chuck53 said, "hey I've got a Catalina and I totally agree."
jackdale likes this.
Capt Tony
CaptTony is offline
post #28 of 126 Old 06-12-2012
jackdale's Avatar
Tony - I took a Hunter 45cc off the west coast of Vancouver Island. When I posted the problems I had on CF I was lambasted. I would take a Hunter offshore AFTER some extensive modifications. I have sailed other Hunters in the protected waters of the Gulf Islands with no problems.
I happen to think the ISAF offshore race rules are good place to check if a vessel is ready for offshore. You may trust your vinyl coated lifelines, but some of the other guidelines are essential.
Here is the checklist for the Vic-Maui race. http://www.vicmaui.org/pdfs/VM2012%2...0B%20Final.pdf
I am bringing one of the boats back to Vancouver. Granted the boat is not comfortable. But the boat is safe.
erps likes this.
jackdale is offline
post #29 of 126 Old 06-12-2012
Hunter did have a lot of problems in their boats made between about 1985-1999. At which point they got a new designer who changes the entire build culture, and made the boats much better.
Again I am not saying I think Hunters are the best built boats in the world, but I know new boats from even the traditional bluewater yards that have come screwed up. Like a S/S Swan with no washers on the winch bolts... or a Hinkley where someone forgot to fully tighten a keel bolt.
Even the best screw up, they just screw up less.
Greg
Stumble is offline
post #30 of 126 Old 06-12-2012
GeorgeB's Avatar
My Catalina 34 MkII, built in 2000 has all Lewmar Ocean Series hatches. She also is equiped with a M35B diesel from Universal/Westerbeke (Kubota block) with a Racor primary filter. I have Lewmar 48’s as primaries and Lewmar 30’s on the coach roof and also as secondary’s. My navigation suite is Raymarine and steering is Edson.
GeorgeB is offline
Tell me your story CraigMiller1 General Discussion (sailing related) 10 10-15-2011 03:46 PM
Here is story for you.. Giulietta Gear & Maintenance 18 11-29-2006 05:55 PM
