-   -   info on 16hp yanmar (http://www.sailnet.com/forums/general-discussion-sailing-related/8857-info-16hp-yanmar.html)
jzlatar 01-08-2004 08:42 AM
info on 16hp yanmar
Hi everybody: any one has information on which is the highest rev for cruising speed for these engines?
Thanks in advance
tahitisail 01-14-2004 07:30 PM
info on 16hp yanmar
My manual shows:
1. Continuous output rating 16hp at 3400rpm
2. maxium output rating 18hp at 3600rpm
3. maxium fuel efficiency at 2700rpm
4. maxium torque at 2900rpm
5. engine flywheel output and propeller power curves crossing at 3400rpm
In flat water with no wind what rpm does it take to get your boat to hull speed?
If you are running into a sea/headwind run it at a higher speed and if you want to conserve fuel run it at 2700rpm
I run mine at a speed that gets me pretty good speed and at a noise level that doesn''t sound like the damn thing is going to jump out of the boat.
fer@fer 01-19-2004 10:30 AM
info on 16hp yanmar
Hi JZ
In this site, a guy has scanned a lot of info, manuals and workshop manual and parts about some engines, among others, Yanmar
http://www.motoren.ath.cx/
Regarding yor specific question, is a page
http://www.boten.nl/~motoren/motoren_pdf/Yanmar.gm-series.pdf
regards
fernando
SEO by vBSEO 3.6.1
