Seized seacock - Page 3 - SailNet Community
 3Likes
post #21 of 26 Old 06-18-2012
Re: Seized seacock
Ok, in the original post it was for the toilet and I missed that the photo wasn't yours. (Why put up a photo that is not a true representation? FYI- A bit confusing for my simple mind.) You should change the valve to a real seacock and put a proper backing plate on the inside of the hull. Having said that, it is a sink drain above the waterline so you might be okay, so sail for the season, limit the use of the sink or come up with an alternative for the drain or do as I mentioned above and take your chances it won't fail mid-season. I have a 1979 sabre 34 and heel quite a bit. Our gas vent is a little higher than 8-inches but essentially is a plastic thru hull with a 3/4 inch hose venting where the propane tank for the stove is. I catch a tiny bit of water in the box where the tank sits but nothing to worry about. This might be true with your sink drain. Best of luck- Joe
ambianceack is offline
post #22 of 26 Old 06-18-2012
Hope Floats
Re: Seized seacock
Try using some pb blaster from local store and spray into seacock from under the boat, and remove hoses to the seacock and spray into it from that angle as well. Wait 20 minutes or so and try acuating it a little at a time. It takes a while to loosen that which has been stuck so long. Cheater bar over the valve handle, but don't break it.
Sabo is offline
post #23 of 26 Old 06-19-2012
travlin-easy's Avatar
Re: Seized seacock
I recently discovered that CLR cleaner works very well at cleaning the surfaces and freeing seacocks and stuck spigots.
Cheers,
Gary
travlin-easy is offline
post #24 of 26 Old 06-20-2012
Senior Junior Member
Re: Seized seacock
sgjfrods,
You've gotten quite a few good ideas presented to you. The best one was take some pictures. Before you do anything, I'd suggest you get someone who's worked on boats and knows his way around them, like a yard person, a surveyor or a really capable boater. It's possible the yard where he kept it or worked on it can help you.
The reason I say that is the red flag inherent in your comment "Iv'e inherrited the boat off my grandad who has unfortunately passed." I'm sure your Grandfather was an accomplished sailor and when active really looked after his boat. However, as we get older things tend to slip through the cracks (I'm 69). It's not uncommon for a boat to spend many years in the water and never used. Then sit on the hard for more years.
The Westerly is a tough English made boat with a lot of old fashioned heavy duty (by todays standards components. But, they may have been sitting for some time.
For example, I'd suggest disconnecting the hoses on each seacock and checking to see what kind of valves they are and in what condition. I'd check all hoses for age. And don't forget the stuffing box hose, it's small but can sink the boat easily. The list can go on.
Also, the westerly is an old boat. see if your Grandfather left any records as to what he replaced or had fixed on it. Anything that can give you a clear insight as to it's maintenance. Especially in the last 5 or 20 years.
They're not a fast boat, but well built and seaworthy. With some time and a few $$$ up front I'm sure your grandfather would be happy seeing it on the water again with you at the tiller.
Fair winds,
jed
Watercolor is offline
post #25 of 26 Old 06-20-2012
Seņor Member
PorFin's Avatar
Re: Seized seacock
Just remember that PB Blaster is going to seriously degrade anything made out rubber -- like o-rings -- internal to the gate valve.
PorFin is offline
post #26 of 26 Old 07-02-2012 Thread Starter
Re: Seized seacock
Thanks very much for your time and help has been much appreciated, I agree with Jed i will get an old hand to help me.
Thanks to Jed for your kind words.
Cheers,
James
sgjfrods is online now
Yanmar seized Islandflyr Diesel 8 10-26-2009 01:22 AM
seacock seized bluwateronly Gear & Maintenance 13 07-09-2008 08:23 PM
Seized turnbuckles zoom555 Gear & Maintenance 2 05-01-2008 11:55 AM
seized screw heads ambianceack Gear & Maintenance 9 11-25-2006 05:16 AM
BVI Boats Seized by US Customs VIEXILE General Discussion (sailing related) 2 07-16-2003 04:05 AM
