whisker pole or spinnaker pole - SailNet Community
 1Likes
post #1 of 12 Old 06-19-2012 Thread Starter
First String
O.K
so anybody that has been reading any of my post knows I am new to sailing. In fact this past weekend was my 3rd trip out as captain. So, that being sail I had some new challenges this weekend. I was told to ask even if I felt the question is dumb.
So the weather called 8 to 10 out of the north east with sunny skies. Moving to south east 8 to 10 by evening. They were off by a few, in fact we had very light air to say the least. on the way back we had a light puff from the stern most of the way. I tried to go wing on wing and did so with some success, however I think I could have set the pole to help the jib stay out. It kept wanting to luff and bunch up on the main. Here is the dumb question:
I have 2 poles one is mounted on the foredeck looks to be 3" in DIA with a jaw clip on both ends. The 2nd pole in mounted to the mast has its own vertical traveler and halyard. It looks to be telescopic in nature. Both are light. Which one is the Whisker pole and which one is the Spinnaker pole? And was this a good time to deploy it in downwind sailing wing on wing?
Thanks for your help.
ltgoshen is offline
post #2 of 12 Old 06-19-2012
Re: whisker pole or spinnaker pole
Telescoping is the whisker pole. Yes. Deploy.
puddinlegs is offline
post #3 of 12 Old 06-19-2012 Thread Starter
First String
All hank up sails on my boat by the way
ltgoshen is offline
post #4 of 12 Old 06-19-2012
As pudding says, the telescoper is the whisker.. use it on the genoa for winging out. The other will the a regular spinnaker pole (should be the same length as distance mast to forestay along deck)
The spinnaker pole would replace the whisker pole on the mast when you're flying the kite, the whisker pole would need to be stowed.
Faster is offline
post #5 of 12 Old 06-19-2012
Learning the HARD way...
eherlihy's Avatar
You are lucky to have both poles!
The telescoping pole is the whisker pole, and it is used to keep the Jib out. It reduces wear on the sail, and helps you keep the sail shape as the boat rolls. I wish I had one.
The pole mounted on the fore deck with jaws at both ends is the spinnaker pole. I have one of these, but without a spinnaker it is just in the way. I leave mine on the dock.
eherlihy is offline
post #6 of 12 Old 06-19-2012 Thread Starter
First String
The pole mounted on the fore deck with jaws seams to be a trip hazzard. I have a red white and blue shoot with a dousing sock but I am no were ready to fly this thing. the wisker pole hangs on the boom out of the way. Iam learning. So if Iam not using the spinnaker for a while i can leave it at the house fore a while. That will give me more learning room on the fordeck without falling overboard. Again thanks
ltgoshen is offline
post #7 of 12 Old 06-19-2012 Thread Starter
First String
I will send a photo of the 2
ltgoshen is offline
post #8 of 12 Old 06-19-2012 Thread Starter
First String
[IMG]Photobucket[/IMG]
These photos are old. I have rescued this boat. it was sinking when I found her. serch this site for East Coast Lady. She looks great now.
ltgoshen is offline
post #9 of 12 Old 06-19-2012
Much better with pictures.. the ring that the whisker pole is attached to seems dedicated to that function - and you have one on each side.
The ring on the sliding track (leading edge of the mast) is the one for the spinnaker pole. So in fact the setup allows you to fly the spinn with its pole (the one on deck) while leaving the whisker in the stowed position...
You really got a lot of good equipment on this boat. I'd stress again to do what you can to have someone with experience spend a day with you to sort it all out and set you straight on how to use it.
Faster is offline
post #10 of 12 Old 06-20-2012 Thread Starter
First String
Thanks faster. We took her out this past weekend and she handles real nice in light air, but the head sail kept having a hard time staying inflated. We had a tail wind and were trying to go wing on wing. It was tough. So next time I will try to hold it open with the pole. Iím at a marina now and getting some great advice on the on deck stuff. I had a guy next dock climb aboard and as he did he told me that the rigging was way too loose. He helped me toon it up using this gauge that the last owner left in the boat.
Sorry for all the uneducated questions. I am learning a lot from this sight. It is packed full of information. I have been using the search function constantly. Talk to ya soon. And thanks again.
I will post a photo of how she looked this past weekend.
ltgoshen is offline
Making a whisker/spinnaker pole? kwaltersmi Gear & Maintenance 1 04-15-2009 05:26 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
Spinnaker vs Whisker Pole jr438234606 Gear & Maintenance 2 04-09-2007 08:46 PM
Whisker Pole vs Cruising Spinnaker r2straebel Gear & Maintenance 5 01-24-2002 08:25 AM
