Choosing a new main sail. - SailNet Community
post #1 of 8 Old 06-19-2012 Thread Starter
Excalibur 26
Stheeb's Avatar
I have an Islander Excalibur 26 and am about to buy a new main sail for her.
I mostly day sail on the Monterey bay but plan to do some costal cruising this season or next. The sail I am looking at is 6.5 oz Dacron.
My question is, is 6.5 oz Dacron a good weight of sail for Day sailing / costal cruising?
Stheeb is offline
post #2 of 8 Old 06-19-2012
DrB
Probably OK,.....
but I assume that you have talked to a (the) sail maker and got their input/recommendation, correct? If not I would do this. One question to have the answer to when speaking with them is "what are the typical wind speeds in the area that you sail in? Also, what wind speeds will you go out in and what ones will you not?
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #3 of 8 Old 06-19-2012
Re: Choosing a new main sail.
Why not call Santa Cruz sails and ask?
puddinlegs is offline
post #4 of 8 Old 06-19-2012
Stheeb,
Mainsail weight and shape are in large part driven by the prevailing winds in the area.
For instance on the Gulf Coast where we almost always have light air, huge roach mains and light weight material are much more common than areas where reefing in commonplace. In fact half the boats here have never reefed their mains, because we don't get the winds to justify it.
I don't know your area, so I couldn't speculate on what would be appropriate for you.
Greg
Stumble is offline
post #5 of 8 Old 06-19-2012
yes, should be good.
"Just call me TB"
capttb is offline
post #6 of 8 Old 06-19-2012
brehm62's Avatar
The standard sail weight for the:
larger Catalina 27 is 6.5 ounces.
larger Hunter 27 is 6.5 ounces.
similar sized MacGregor 26M is 5.5 ounces.
1980 Southcoast Boats Explorer #34
Copy of International 21.
No connection to South Coast Seacraft.
brehm62 is offline
post #7 of 8 Old 06-19-2012
chef2sail's Avatar
My first keelboat was an Islander 28, very much an anaomoly here on the east coast.
I think for coastal cruising and the larger winds you experience there you might want to go up to 7.3 oz. Make sure you get at least two reef points.
I would suggest Quantum sails for you to talk with and visit to get some information. Not all sails are the same and they can help tailor your needs to your sailing area and sailing profile, Their sails are a little more money...but customers service and fitting can be important. Read some of the other threads on Sailnet about sail lofts too. Be very carefully about going the internet way.
You will have the sails 10+ years,,,going cheap may cost you more in the long run. They are the engines for your boat.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #8 of 8 Old 06-20-2012
This doesn't consider the cut of the sail, venue conditions, no. of reef points,etc... OP, call Santa Cruz sails or maybe ring Pineapple up in SF for some ideas. You're in an area with many good options.
Main sail sailorboy2 Hunter 1 12-05-2010 08:58 PM
main sail help diverdad69 Gear & Maintenance 3 06-07-2009 11:53 PM
Main Sail NCountry Gear & Maintenance 15 11-24-2008 08:22 PM
new main sail mastercpo Gear & Maintenance 0 11-23-2002 12:35 PM
Choosing a Sail Dan Dickison Racing Articles 0 09-23-2002 08:00 PM
