My seaon is screwed GRUESOME IMAGE - Page 5 - SailNet Community
 7Likes
post #41 of 51 Old 06-21-2012
Seņor Member
ottos's Avatar
Re: My seaon is screwed GRUESOME IMAGE
I bet butyl tape would seal out the moisture and let you shower....
Mainesail, do you have a page on that?
Ouch, Tom...heal fast!
ottos is offline
post #42 of 51 Old 06-21-2012
Skipper Jer's Avatar
And this is why I keep a bottle of superglue in my toolkit.
Skipper Jer is offline
post #43 of 51 Old 06-21-2012
Water Lover
Location: New Mexico, USA (Heron, Elephant Butte lakes); Arizona (Lake Pleasant)
You have sympathy and respect. There's a lot of discussion of packaging-related injuries, so, sadly, you're very much not alone.
http://www.cpsc.gov/library/hazard_packaging.pdf
A gift can leave you in stitches - USATODAY.com
from the above: "Eric Kent made it through two tours of duty in Iraq and one in Afghanistan with hardly a scratch.
Yet a Marine who took on terrorists and insurgents abroad turned out to be no match in one of the USA's most common domestic smackdowns: man vs. product package."
Product Packaging Injures Thousands Every Year
Ho ho woes: Wrap rage results in lacerations and bad tempers - amednews.com
From the American Medican Assn. article:
<<"I've worked in the emergency department on Christmas day for six out of the last 10 years. We certainly see lacerations. That's the most common thing. But we also see punctures," said David Ross, DO, an emergency physician at Penrose Hospital in Colorado Springs, Colo. He also is a spokesman for the American College of Emergency Physicians. "That clamshell packaging is absolutely diabolical.">>
rgscpat is offline
post #44 of 51 Old 06-21-2012
Last spring I was going down to work on my boat with my dad who was 82 at the time. He calls me at 5:30 am on a Sunday and says pick up some big band aids on my way over, he took a little fall. I get there and he is sitting in the chair with a bloody towel around his arm. The first thing he says is "I'm not wasting time at the hospital on a Sunday. I'll just keep it wrapped in a towel and we can go down to the boat. I'll get it patched up on Monday!" He lowers the towel and he is cut almost from the wrist to the elbow! He said it took him half an hour to clean up all the blood on the floor.
I take him to the emergency room at 7:00 am. There is one doctor and one nurse. He gets an xray, and electrocardiagram, and I help the doctor stitch him up with 26 stitches, because the nurse is busy with another patient. We're on the road to the boat by 9:00 am! A new record for a hospital visit!
Gary H. Lucas
GaryHLucas is offline
post #45 of 51 Old 06-21-2012
Not to down play your nasty wound, but I know of a worse one .Guy I know was cutting aluminum in the bilge with a carbide toothed blade on an angle grinder.Arms length between his legs when it jammed and took on a life of it's own. Apart from making a mess of his gum boots ,it severed tendons in both forearms and a few lesser cuts.
Capt Len is offline
post #46 of 51 Old 06-21-2012
sunfish?junior?
I am sorry to see your pain. Maybe we will all think of you as we make a cut. I see you work with a lot of SS. and it can have very sharp burrs. Did I read right and you said it was cutting the top of a plastic water bottle and act many of us do? Because you have posted this someone may think for just enough time to avoid the same fate. Thank You Get well soon Lou 452
Lou452 is offline
post #47 of 51 Old 07-02-2012 Thread Starter
tommays's Avatar
Re: My seaon is screwed GRUESOME IMAGE much better shape :)
Much better in only two weeks and no infection which was the biggest worry
30 days in cast number two and then a custom splint to keep me in-line
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #48 of 51 Old 07-03-2012
captflood's Avatar
GREETINGS EARTHLINGS ; Looks a neat job and that means your well on your way for mendding. Heal well and soon DO NOT GRAB ANYTHING TOO TIGHT WITH YOUR LEFT HAND.
GO SAFE
captflood is offline
post #49 of 51 Old 07-03-2012
If its not too nosy, let us know the total cost. This looks to be 25 grand or so.
post #50 of 51 Old 07-03-2012 Thread Starter
tommays's Avatar
I dont know the cost BUT there is less than 2 hours of ER work and a < 1 hour office visit involved so far
As it is under workmens comp it will be kept LOW
Tommays
Northport NY
tommays is offline
Gruesome Discovery Aboard Burned Boat - abc7.com NewsReader News Feeds 0 04-29-2006 06:15 AM
SCREWED nauticalrich General Discussion (sailing related) 9 08-26-2002 05:17 AM
Help!! I am sinking..(i screwed up) gjl6665 Gear & Maintenance 1 06-11-2002 02:51 AM
