Rudder Washers - SailNet Community
post #1 of 3 Old 06-21-2012 Thread Starter
Rudder Washers
I have been looking for the rubber washers that go over the rudder shaft and are located between the top of the rudder and the bottom of the hull. Approx size is 1 3/4 OD and 2 inch ID. Thickness 1/8 to 1/4 inches. Either split or complete. I have looked in the local chandlerys, hardware stores and ebay with no success. Can anyone point me in the right direction. Thanks
weephee is offline
post #2 of 3 Old 06-21-2012
tommays's Avatar
Re: Rudder Washers
I would think there somewhat custom to each brand of boat as there is really no standard rudder post size
All of mine have a much wider face as 1-3/4 x 2 would only have a 1/8 wide surface and i would think you would want 3/8 to a 1/2 face
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 3 Old 06-21-2012
Chastened
Ajax_MD's Avatar
Re: Rudder Washers
Sounds to me like you're looking for rudder bearings. These are often made of Delrin. What kind of boat? Like Tommays says, they'll be custom but someone probably makes them.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
2.25" ID thrust washers? deniseO30 Gear & Maintenance 13 05-07-2012 03:48 AM
Crush Washers aa3jy Diesel 6 01-12-2012 08:20 PM
How Crucial are Washers? Harborless Gear & Maintenance 9 08-26-2011 01:50 PM
Pressure Washers TakeFive Gear & Maintenance 29 08-20-2011 11:36 PM
Annealing Copper Washers W.Ritchie Gear & Maintenance 1 08-31-2001 08:13 AM
